This should just pull out - right? |
Tdskip |
Oct 28 2019, 06:31 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
914werke |
Oct 28 2019, 06:33 PM
"I got blisters on me fingers" Group: Members Posts: 10,123 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
squeeeez...
IronHillRestorations |
Oct 28 2019, 07:26 PM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Take off the other end and leave it connected to the gauge
Oct 28 2019, 07:29 PM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tdskip |
Oct 28 2019, 07:33 PM
Thanks for the responses.
I’d imagine it is a very small tip screw driver? |
Jamie |
Oct 28 2019, 07:47 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Trying to change the dash gauge faceplate and this is the last thing holding me up. I am leery of pulling too hard befor I check. She is a pretty original ‘73 1.7. Thanks! k I've never seen the back side of the dash instruments, is this the speedo or tach? I need to fix the dead odometer this winter and have been checking references for the process. (IMG:style_emoticons/default/wacko.gif) |
Oct 28 2019, 08:00 PM
jmitro |
Oct 28 2019, 08:20 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I've never seen the back side of the dash instruments, is this the speedo or tach? I need to fix the dead odometer this winter and have been checking references for the process. (IMG:style_emoticons/default/wacko.gif) the gauge he is holding is the speedometer. the item circled is tripmeter reset |
FlacaProductions |
Oct 28 2019, 08:22 PM
Senior Member Group: Members Posts: 1,610 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@Jamie - that's the speedo and the attachment in question is the short cable for the odometer reset dial. do NOT turn it while the car is in motion.....
rgalla9146 |
Oct 28 2019, 08:26 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yes, it does pull out.
Use a curved needlenose plier to lever off back of case. Marks suggestion is correct too. How's your eyesight ? |
Tdskip |
Oct 28 2019, 08:39 PM
Thanks all, will try pulling it again
Larmo63 |
Oct 28 2019, 08:55 PM
The whitish collar "clamps" into the back of the gauge.
A bit tricky, but it will come out. |
framos914 |
Oct 29 2019, 09:53 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Trying to change the dash gauge faceplate and this is the last thing holding me up. I am leery of pulling too hard befor I check. She is a pretty original ‘73 1.7. Thanks! k I've never seen the back side of the dash instruments, is this the speedo or tach? I need to fix the dead odometer this winter and have been checking references for the process. (IMG:style_emoticons/default/wacko.gif) Just repaired mine, followed instructions on pelican site. The metal gear starts to slip, squeezed it as instructed. was kind of a PITA but works fine now. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:13 PM |
