I've never seen the back side of the dash instruments, is this the speedo or tach? I need to fix the dead odometer this winter and have been checking references for the process.
Oct 28 2019, 08:00 PM
QUOTE(Tdskip @ Oct 28 2019, 09:33 PM)
Thanks for the responses.
I’d imagine it is a very small tip screw driver?
Yes. I modified one with a file until it fit perfectly.
jmitro
Oct 28 2019, 08:20 PM
QUOTE(Jamie @ Oct 28 2019, 08:47 PM)
the gauge he is holding is the speedometer. the item circled is tripmeter reset
FlacaProductions
Oct 28 2019, 08:22 PM
@Jamie - that's the speedo and the attachment in question is the short cable for the odometer reset dial. do NOT turn it while the car is in motion.....
rgalla9146
Oct 28 2019, 08:26 PM
Yes, it does pull out. Use a curved needlenose plier to lever off back of case. Marks suggestion is correct too. How's your eyesight ?
Tdskip
Oct 28 2019, 08:39 PM
Thanks all, will try pulling it again
Larmo63
Oct 28 2019, 08:55 PM
The whitish collar "clamps" into the back of the gauge.
A bit tricky, but it will come out.
framos914
Oct 29 2019, 09:53 PM
QUOTE(Jamie @ Oct 28 2019, 06:47 PM)
QUOTE(Tdskip @ Oct 28 2019, 04:31 PM)
Trying to change the dash gauge faceplate and this is the last thing holding me up.
Just repaired mine, followed instructions on pelican site. The metal gear starts to slip, squeezed it as instructed. was kind of a PITA but works fine now.
