Thunderchief |
Member ![]() ![]() Group: Members Posts: 176 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California ![]() |
There's a 914-6 conversion on EBay that mentions side shift transmission but I've also seen tail shift as well and was wondering what applications work for each one. Thanks.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Quick answer, tail shift is less desirable.
As you might assume, it is how the linkage connects and interacts with the transmission. Sideshift was an improvement over the earlier tail shift design. The transmission is the same, it's just the way the linkage connects. Experts will enter in, but in the mean time, here's some reading material: https://www.google.com/search?sxsrf=ACYBGNT...DCAg&uact=5 |
RickS |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None ![]() |
Quick answer, tail shift is less desirable. As you might assume, it is how the linkage connects and interacts with the transmission. Sideshift was an improvement over the earlier tail shift design. The transmission is the same, it's just the way the linkage connects. Experts will enter in, but in the mean time, here's some reading material: https://www.google.com/search?sxsrf=ACYBGNT...DCAg&uact=5 Amen brother. |
Thunderchief |
So are the transmissions interchangeable?
Rand |
If that wasn't clear in the first post where I said the transmission was the same:
The transmissions are the same. The linkage is different. |
Rand |
If you don't understand the linkage, then no you can't just swap them out even though the tranny is the same.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
72 and earlier cars had the tail shift trans.
73 and later cars had the side shift trans. To swap a side shift in you need the complete shift linkage from the shift lever all the way to the transmission. You can reuse the shift knob, if you can get it off without breaking it. Also the side shift has a shift console ( on the side) and the 3 internal shift rods in the transmissions are different between tail shift and side shift. So you can get a side shift trans to go with the complete linkage and swap in. Or you can get the shift console and internal shift rods and convert the tail shift trans to a side shift trans. Some assembly required. You also need a firewall conversion shift rod bushing and if it is stock 4cly car you need 73 and later engine cross bar and engine mounts. So if you are buying a car get one with the side shift trans if you can. But if everything else makes a car with tail shift trans the better car it can always be converted to a side shift trans later. Jim |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
also need later motor mounts and engine mount bar for side shifter
Thunderchief |
Really good info guys, I really appreciate it. Thanks
80’s old school |
Member ![]() ![]() Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California ![]() |
Honestly, the difference is “works vs. don’t work”.
Converting my 1970 from tail shift to side shift was the single biggest improvement I have made to the car... bar none. Tail shift = Like shifting a stick in a jar of mayonnaise. Side shift= much better, still not as good as a direct shift transmission, but now usable. If you have not done the conversion... do it!!! |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I beg to differ here on the side vs tail debate. I too had held the side as the “best” version. Uniting I got my 72. It shifts every bit as good as my side shift cars.
The real problem with the tail shift is that it’s much more complicated to make work correctly. I prefer the side shift, but the tail can be made to work just as good as the side. |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
When I had my 1971 recommissioned, I kept the tail shift. With new bushings I just love it. It's sloppy and it works fine and reminds me of my first 914, the 1971 car that I got in 1974. Nostalgia conquering reason. To each his own. BTW my other three are side shifts and yes, they do shift a lot better.
Paul |
Lo-Fi Version | Time is now: 13th July 2025 - 10:36 AM |
