seat out.....take relays out ?, 1974 914 1.8 |
brcacti |
Nov 2 2019, 03:52 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
brcacti |
Nov 2 2019, 05:46 PM
Hello, I ended up taking the small one out and putting the big one back in. Someone on here said to disconnect the small one, and should not have to join the two yellow wires then. Any input would be great for this.
FlacaProductions |
Nov 2 2019, 08:53 PM
Senior Member Group: Members Posts: 1,593 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I left them both in and connected the two fat yellow wires like this:
jcd914 |
Nov 2 2019, 11:11 PM
No matter what you do with the relays, you have to connect the two large yellow wires together..
They are the power circuit to the starter. Jim |
brcacti |
Nov 3 2019, 12:35 PM
No matter what you do with the relays, you have to connect the two large yellow wires together.. They are the power circuit to the starter. Jim oh, maybe I goofed, I took out the small relay, left the big one in, opposite from what the picture shows here. The two big yellow wires are still going into the big relay. I thought I needed to take out the SMALL relay pictured here. If we have people here that knows please let me know. |
FlacaProductions |
Nov 3 2019, 04:49 PM
don't worry about the relays - just do the two big yellow wires...report back.
brcacti |
Nov 3 2019, 06:39 PM
JeffBowlsby |
Nov 3 2019, 08:13 PM
914 Wiring Harnesses Group: Members Posts: 8,513 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
DONT CUT ANYTHING!
Get the splice housing. Depress the tangs holding them in teh housing to remove. Insert into the splice housing. |
brcacti |
Nov 4 2019, 03:52 PM
sixnotfour |
Nov 4 2019, 03:57 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE Sorry, I saw your message AFTER I had done the job, just leave it at this...... |
brcacti |
Nov 5 2019, 06:13 PM
QUOTE Sorry, I saw your message AFTER I had done the job, just leave it at this...... I got in trouble..............the car does not crank now at all and I can't even jump it at the add on solenoid/relay like I was able to do before. I bought some connections and RE-CONNECTED THE two big yellow wires and still the same. I have to double check to see if I plugged them in the same place as they first came from. |
FlacaProductions |
Nov 5 2019, 09:15 PM
does not crank or does not start?
did you disconnect the battery before you did this work? |
brcacti |
Nov 6 2019, 05:13 AM
does not crank or does not start? did you disconnect the battery before you did this work? No, did not disconnect the battery. does not crank, I can hear some noises when key is turned. I use to be able to jump start it from the add on starter relay but not now. I will recheck the yellow wires to see if both are in the right place. |
FlacaProductions |
Nov 6 2019, 11:45 AM
put the yellow wires back and see if it cranks.
brcacti |
Nov 6 2019, 02:53 PM
put the yellow wires back and see if it cranks. Hello, yes I put new connections on the two yellow wires and plugged them back into where they were before, won't crank. From the add on starter relay I get a reading of 12.47 from the big black to the yellow and same reading from the big black to the white. NO READING from the big black to the 1/4 inch nut connection that I used to jump start this way, now nothing. Did I burn out my add on starter relay? |
brcacti |
Nov 6 2019, 03:19 PM
put the yellow wires back and see if it cranks. Hello, yes I put new connections on the two yellow wires and plugged them back into where they were before, won't crank. From the add on starter relay I get a reading of 12.47 from the big black to the yellow and same reading from the big black to the white. NO READING from the big black to the 1/4 inch nut connection that I used to jump start this way, now nothing. Did I burn out my add on starter relay? FORGET this post, in all my inexperience and haste I forgot to plug one wire from the add on starter relay into the starter, I CAN JUMP START IT NOW AGAIN (IMG:style_emoticons/default/smile.gif), the relay is not bad. It still does not start from the key, may be a bad ignition switch, will try another test |
porschetub |
Nov 6 2019, 04:49 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If you have bridged the 2 large yellow wires together the car will crank and start regardless of the relays being in place,use a sealed connector such as a Duraseal (yellow) so no moisture can get in there,make sure the yellow wire that leads off here is a good fit on the starter solenoid....you should be good.
Lo-Fi Version | Time is now: 23rd May 2024 - 02:40 PM |
