QUOTE(brcacti @ Nov 6 2019, 01:53 PM)
QUOTE(FlacaProductions @ Nov 6 2019, 10:45 AM)
put the yellow wires back and see if it cranks.
Hello, yes I put new connections on the two yellow wires and plugged them back into where they were before, won't crank. From the add on starter relay I get a reading of 12.47 from the big black to the yellow and same reading from the big black to the white. NO READING from the big black to the 1/4 inch nut connection that I used to jump start this way, now nothing. Did I burn out my add on starter relay?
Click to view attachment Click to view attachmentFORGET this post, in all my inexperience and haste I forgot to plug one wire from the add on starter relay into the starter, I CAN JUMP START IT NOW AGAIN
, the relay is not bad. It still does not start from the key, may be a bad ignition switch, will try another test
