Speedo Drive Gear leak & transmission fluid recommendation, 914Rubber gear guide solution? |
dcecc1968 |
Nov 4 2019, 08:52 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
I got my 914 back on the road and after parking in the garage, noticed oil on the garage floor on the passenger side below the heat exchanger, and elsewhere along the transmission.
From searching other 914World threads, I noticed that the speed gear is common leak spot, but I need to clean the area to see exactly where the leak is originating. Is the below 914rubber part the recommended fix and is there another gasket that I should purchase, or will the guide take care of it? Also, need a transmission fluid recommendation if there is something better than recommended in the Haynes Manual... prefer a fluid I can get at the LAPS. |
Mikey914 |
Nov 4 2019, 09:54 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You will note the part has an extra channel on the lower edge that has a completely new seal factory never made them like this.
Factory Attached thumbnail(s) |
Mikey914 |
Nov 4 2019, 09:59 AM
The one we make.
You can see how the extra seal is below the mount bolt. It's just a second line of defense between your transmission and the garage floor. https://900designs-container.zoeysite.com/s...bushing-kit-1-1 Attached thumbnail(s) Attached image(s) |
dr914@autoatlanta.com |
Nov 4 2019, 10:05 AM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
speedo o ring, and speedo main seal, two parts will solve the problem, then fill with 80/90 weight oil
Mikey914 |
Nov 4 2019, 10:23 AM
Yes the new seal do help, but adding an additional one makes sure it will not leak. There is a reason we make these, it's not just for fun. (IMG:style_emoticons/default/biggrin.gif)
maxwelj |
Nov 4 2019, 10:45 AM
rebuilt member Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None |
I can vouch for Mikey's seal. Had a bad leak marking it's spot, then replaced with Mikey's (914Rubber) drive and the leak stopped. Only issue was figuring out which way the internal seal was supposed to go, but a simple question got that answered and we were good to go.
Tdskip |
Nov 4 2019, 10:54 AM
Nothing fancy needed as far as transmission oil goes, manual is fine.
dcecc1968 |
Nov 4 2019, 02:32 PM
Thanks for the feedback. Once I confirm this is my leak, I'll make my 914 Rubber purchase. Mark, do you have any use for the old "core".
On the oil, looks like most agree that 80W90 GL-5 is the proper spec. To fill: remove the fill plug first (after finding the elusive 17mm hex wrench) and it takes 2.5 to 3 quarts to fill, and fill on level surface, .... does that sound about right? |
Tdskip |
Nov 4 2019, 02:35 PM
Thanks for the feedback. Once I confirm this is my leak, I'll make my 914 Rubber purchase. Mark, do you have any use for the old "core". On the oil, looks like most agree that 80W90 GL-5 is the proper spec. To fill: remove the fill plug first (after finding the elusive 17mm hex wrench) and it takes 2.5 to 3 quarts to fill, and fill on level surface, .... does that sound about right? Amazon has the Allen head you need, fill to just starts to weep out, simple if potentially messy job. |
Mikey914 |
Nov 4 2019, 03:14 PM
Thanks for the feedback. Once I confirm this is my leak, I'll make my 914 Rubber purchase. Mark, do you have any use for the old "core". On the oil, looks like most agree that 80W90 GL-5 is the proper spec. To fill: remove the fill plug first (after finding the elusive 17mm hex wrench) and it takes 2.5 to 3 quarts to fill, and fill on level surface, .... does that sound about right? Not really, we machine all from billet, you can find tolerances in the shaft will expand from wear to so all is back to factory. Thanks though. Mark |
soccerplyr |
Dec 15 2019, 02:14 PM
Newbie Group: Members Posts: 25 Joined: 31-August 13 From: Sandy, Utah Member No.: 16,329 Region Association: Rocky Mountains |
I have the same issue and am trying to install the new gear guide. Is there a trick to it? I can't get it to go into the case once it gets to the second seal.
rhodyguy |
Dec 15 2019, 04:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If no hex and the plug will budge, you can use a double/jam nutted bolt with a 17MM head. Let some penetrant work first.
Mark Henry |
Dec 15 2019, 05:29 PM
I use an clean piece of cardboard, slide it under over night, then without moving it I look to see exactly where the drip is coming from. Best to find exactly where it's coming from first.
Lo-Fi Version | Time is now: 5th May 2024 - 02:22 AM |
