WTB Eight hose clamps for drain funnel |
Jett |
Nov 4 2019, 06:08 PM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Hello, we are looking to buy a small stash of drain funnel hose clamps. Looking for eight hose clamps that we can plate.
We need #41 (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Mikey914 |
Nov 5 2019, 09:09 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
When you plate springs they need to be heat treated after. I suspect that was Bruce's issue. Most plating companies know this, so if you are using a commercial facility, you should be fine.
Jett |
Nov 5 2019, 04:27 PM
bdstone914 |
Nov 5 2019, 06:17 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Jett date='Nov 5 2019, 04:27 PM' post='2759646']
[quote name='Mikey914' post='2759554' date='Nov 5 2019, 07:09 AM'] When you plate springs they need to be heat treated after. I suspect that was Bruce's issue. Most plating companies know this, so if you are using a commercial facility, you should be fine. [/quote] Thanks Mark [/quote] I believe the process after plating is to bake the parts. The time and temperature is based on the hardness. I do not know of any commercial platers that offer that service. Perhaps one on aerospace. Bruce |
Lo-Fi Version | Time is now: 4th May 2024 - 03:48 AM |
