rear shocks, any tricks before I go in? |
tat2dphreak |
Jul 1 2005, 10:48 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
any tricks to replacing the rear shocks? anything I should watch for?
I'm pulling the KYBs and putting on Bils this weekend... are pre-loaded springs better than the shorter ones? |
MarkG |
Jul 1 2005, 10:53 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
A fairly easy job, need a spring compressor. My Bilsteins had 5 slots to adjust the height. I put mine on 3rd slot from the bottom, which was very low. Shop that did my alignment moved it up 1 notch.
The lower bolts are a bit tricky if you have a sway bar, but job should take a couple hours. |
URY914 |
Jul 1 2005, 10:58 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Don't just remove that nut off the top of the shock in the trunk and let the trailing arm drop. You need to put a jack or block up the trailing arm before you remove the nut. That trailing arm is heavy. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Paul |
tat2dphreak |
cool, I looked it over, looked easy, I have a compresser, and an air ratchet to tighten... just didn't want anything sneaking up on me (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
I have short 100-120lb springs and stock 100lb springs, the short springs won't preload except at the TOP bilstien setting... should I use the stock ones, or the shorter ones? and should the short ones be on the top setting? |
tat2dphreak |
Jul 1 2005, 10:59 AM
glad you reminded me, I can see my dumb-ass forgetting that.! thanks!! |
echocanyons |
Jul 1 2005, 11:09 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Feeding the bolt through the trailing arm can be tricky be careful not to mash the threads.
Joe Bob |
Jul 1 2005, 11:27 AM
Use a jack under the arms to lift and then feed the bolt thru....consider putting on some D rings for tie downs if you ever trailer it....
Andyrew |
Jul 1 2005, 11:58 AM
Jack up the back, put a jackstand under the trailing arm... give it a couple inches of clearance so the shock/spring assembly will come out... Take off the nut on the bottom of the shock, use an impact wrench to take the one off the top... use a mallet or such to get the bottom bolt out of the way.. and bingo! all done.
ya.. you'll need a spring compressor.. and you'll hate it... |
spare time toys |
Jul 1 2005, 12:16 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I got some of them here if you want. Just let me know Larry |
qa1142 |
Jul 1 2005, 12:39 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Took me ~1 hr to change my OEM's today to same setup you bought
I have Hyper coil coil overs with #125 Went easy. set ride hight Billstiens rock |
tat2dphreak |
Jul 1 2005, 01:28 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) cool, that's a great idea, I'll send you a pm Larry! thanks. if I do not use pre-load springs how do you keep them lined up on the top "perch"? |
ClayPerrine |
Jul 1 2005, 01:31 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
zip ties.. tie the springs to the plates.
tat2dphreak |
Jul 1 2005, 01:37 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) and just leave them? or what? |
Andyrew |
Jul 1 2005, 01:47 PM
Yup.. zip tie the top of the spring to the plate... You could do the bottom one's as well.. but I bet they'd break.
Keeps things in line... ie extra protection. |
jhadler |
Jul 1 2005, 02:56 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Of course! It's not like there are any serious loads in that direction that you need to worry about. I have Koni's with the adjustable threaded collar, and with the car jacked off the ground, the bottom of the coil is a couple inches above the saddle. Once the car is back on the ground, no worries... -Josh2 |
tat2dphreak |
Jul 2 2005, 12:12 PM
I get the D rings from larry in a bit, but they will have to wait to be installed... because the rear shocks are DONE!! it took me longer to load the new springs onto the shocks than it did to swap the shocks... the only pain was removing the brake and rotor to get to the bottom bolt. took about 2 hours for everything... not counting the time spent with the guy down the way... he used to have 914s and 911s that he auto-x'd with but is now working on a Triumph TR-6... sweet ride, and a great guy!
oh, if anyone needs some KYBs with good springs, lmk... these springs are weltmeister and still have the printing on them... I think they are only 100# springs though... |
Rusty |
Jul 2 2005, 01:23 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Removing brake and rotor for access to the bottom bolt? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Uhhh, do you have some radical custom suspension or something? -L |
redshift |
Jul 2 2005, 01:29 PM
you don't have to do anything to hold the spring in, if you don't mind a little spirited driving to pop them back in after you lower the car.
M |
tat2dphreak |
Jul 2 2005, 02:10 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) I didn't have the right size wrench, so, I was able to get to it with a socket, but only after removing the rotor... but I thought about turning the bolt around to where the nut would be on the inside... easier to get to the next time... are they supposed to be that way to begin with? |
Joe Bob |
Jul 2 2005, 02:11 PM
Shheeesh....I used a crescenthammer.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 06:45 AM |
