Gear box - selecting 2nd gear - help, Gear box - selecting 2nd gear - help |
dangermoose |
Nov 11 2019, 08:44 AM
Newbie Group: Members Posts: 11 Joined: 21-September 19 From: Poole UK Member No.: 23,483 Region Association: England |
Hello...
Thanks for everyone's help solving my alternator issues! On to the next problem!! I have a tail shift gear box. Selects well 80% of the time, though crunches going from 1st to 2nd, mostly when pulling off up-hill! Any ideas why the synchro is playing up in these situations & what I can do, obviously other than pay a lot for someone to take the box apart? Cheers. Dave UK |
porschetub |
Nov 11 2019, 02:15 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hello... Thanks for everyone's help solving my alternator issues! On to the next problem!! I have a tail shift gear box. Selects well 80% of the time, though crunches going from 1st to 2nd, mostly when pulling off up-hill! Any ideas why the synchro is playing up in these situations & what I can do, obviously other than pay a lot for someone to take the box apart? Cheers. Dave UK Are your bushes all in good condition and is the system adjusted properly ?,I found crunching was more consistant in the lower gears when my cable wasn't adjusted correctly ,found it had stretched a bit from new and adjusted it was fine. |
dangermoose |
Nov 12 2019, 06:22 AM
Bushes on the changer rod system? - These are all new & seems to move around well & the crunching is mainly when pulling off up hill.
Cable? - Do you mean clutch? This seems fine & biting point is high on the peddle. Hello... Thanks for everyone's help solving my alternator issues! On to the next problem!! I have a tail shift gear box. Selects well 80% of the time, though crunches going from 1st to 2nd, mostly when pulling off up-hill! Any ideas why the synchro is playing up in these situations & what I can do, obviously other than pay a lot for someone to take the box apart? Cheers. Dave UK Are your bushes all in good condition and is the system adjusted properly ?,I found crunching was more consistant in the lower gears when my cable wasn't adjusted correctly ,found it had stretched a bit from new and adjusted it was fine. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:41 AM |
