Trying to start my carbureted 1.7, Electrical help |
pastormacman |
Nov 11 2019, 11:21 AM
Newbie Group: Members Posts: 28 Joined: 6-July 05 From: Bakersfield, CA Member No.: 4,382 |
Issue: There's no power going to the coil/fuel pump when I turn the key. (you can skip the history and jump down to the ALL CAPS and (IMG:style_emoticons/default/popcorn[1].gif) to see more about the issue)
History: 16 years ago, this was a running 1.7 fuel injected '73 in Bakersfield, CA. I bought it wrecked in the front end, (hood crunched a little, passenger fender dented) A friend straightened the trunk, cut off and welded a replacement fender on and we put on a replacement hood. I had it painted and new tires on it. It was my daily driver for a couple of years. 14 years ago, I got a new daily driver and this sat for a few months. Unbeknownst to me, a critter made it's home around one of the cylinders with mud and leaves. I went to drive it and the cylinder overheated and seized the engine. I bought new cylinders and took it to a friend to replace. Upon removing the engine he discovered that my block was cracked. I found a rebuilt 1.7 down in Los Angeles and bought it to replace the old engine. My mechanic friend was going to work on it in his spare time for me. I had always had trouble with the fuel injection, so I saw this as an opportunity to remove it and replace it with carbs. So he installed the carbs and after he got the engine back in the car, he discovered his dog had eaten the wiring harness (From the relay plate to the alternator/starter) At that point, life happened... kids grew up, I worked a lot and the car sat in that condition in one of the bays in his shop for 10 years. Three years ago, my sons are now teenagers, and I decided I wanted to finish it up and get it out of my friends way. He had kind grown resentful of it being there. I brought it home and put it on jack stands in my garage. I ordered a new wiring harness and tried to finish the car to get it started for my kids to drive. I discovered that through life I had developed a strong case of claustrophobia and it's difficult to get under the car for me. So it has sat for another three years. So I have a new friend who rebuilds VW Bugs who is now helping me.We've gotten all the electrical hooked back up. Removed the gas tank and flushed it out. replaced all the fuel lines, and filters. And got a new battery. Which brings me to the present... (IMG:style_emoticons/default/popcorn[1].gif) ISSUE: WHEN WE TURN THE KEY, THERE'S NO POWER TO THE COIL OR FUEL PUMP. Since we replaced the fuel injection with carburetors, we no longer have the ECU in the car. (in fact, I no longer have the ECU or any of the fuel injection parts anymore, they are long gone at my other friends garage) Not sure if that was a mistake, I thought I didn't need it anymore since the FI was gone. My VW friend is not familiar enough with 914 electrical to find the issue. Could I have a bad relay? I see that there is a port for the white wires from the ECU to connect to the relay panel. Is there a part I need there in place of the ECU wiring? Is this a common issue with a carb replacement? Other electrical things work, (headlights, and whatnot) and if I continue to turn the key, the starter starts to crank, but no power to the coil/fuel pump. Any help would be appreciated. Sorry for the long post. |
Spoke |
Dec 8 2019, 10:23 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can test the relays involved with providing the power to the fuel pump.
Check out the relay board layout below. Notice the POWER SUPPLY relay in the middle of the board. This relay provides power to the ECU (not installed) and the relay to power the fuel pump. Turning the key to ON will power the Power Supply relay. You can check this switched voltage at the ECU connector. See the wire leaving the Power Supply relay pin 87. This is switched power. It goes to Fuel Pump Relay pin 85 and ECU pin I. To test the Power Supply relay, first remove the connector to the engine. This will keep the coil/points/Pertronix from overheating as you debug the fuel pump issue. Also we need access to pin 12. After the connector to the engine is removed, turn the ignition key to ON. This will cause the Power Supply Relay to turn on and provide 12V to pin I of the ECU plug. With your voltmeter, measure pin I to chassis. You should see 12V. If you do, then the Power Supply relay is good. Once the Power Supply relay is tested good, then check the output of the Fuel Pump relay. Power to the fuel pump comes from the 25A fuse on the relay board. Check the voltage on both sides of the fuse. Check the fuse holder, not the fuse for power. You should see 12V on both sides. Once the 25A fuse is tested ok, with ignition key still on, notice the voltage to the fuel pump comes from Fuel Pump relay pin 87. Follow that wire upwards to the 14-pin connector to the cabin and fuel pump. You cannot measure the voltage there as the connector is still on. However, follow the wire from Fuel Pump relay pin 87 DOWN the page then over to the right to the connector to the engine. You've already removed this connector. Thus the fuel pump voltage from the relay can be measured on pin 12. Let us know what you find. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 30th April 2024 - 06:10 AM |
