Factory assembly or someone’s attempt at weather exclusion?, Found this material holding the trim on the windshield rearward seals |
mgphoto |
Nov 13 2019, 05:57 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I removed the weatherstripping for the windshield rearward seal, (between the doors and windshield), I found a black silicone sealant material between the trim and the windshield frame. I found the same material holding the windshield surround trim in place. I know this is not a typical factory installation.
I am restoring the windshield and surround, so my question is “did the factory use a sealant on the trim between the windows and windshield?” See images below. Thanks Mike |
dlee6204 |
Nov 13 2019, 06:06 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
You sure it’s a silicone product? The factory did use a black sealant but it was more of a butyl type product.
rgalla9146 |
Nov 13 2019, 06:28 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
You sure it’s a silicone product? The factory did use a black sealant but it was more of a butyl type product. :agree The alloy / trim seal holders will be difficult to remove because the butyl between them and the body is very stuborn. Often the trim is bent in the process. If there was no sealant there water would have a direct path inward. |
Lo-Fi Version | Time is now: 9th May 2024 - 12:28 PM |
