Anyone disassembled/restored seat belt receivers |
doug_b_928 |
Nov 15 2019, 11:35 AM
I did a search but didn't see any posts showing the disassembly/reassembly/restoration of the female seat belt receivers. Mine are pictured below. I've ordered new stickers but would like to replate the screws on the back and the main steel portion (mine were very corroded where they bolt into the car; I put POR15 on them a couple of years ago but I'd rather disassemble, media blast and replate the whole thing). Any advice based on past experience with disassembly/reassembly would be much appreciated (as always).
johnhora |
Nov 15 2019, 01:15 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Just remove the 4 small screws you see on the backside and the two plastic top/bottom parts can be carefully pried apart.
The screws are small so be easy on the removal so as not to mess up the topside plastic. Once they are removed it becomes obvious what can be cleaned up and this also lets you replace the "Press" sticker which are available. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:35 PM |
