Anyone disassembled/restored seat belt receivers |
doug_b_928 |
Nov 15 2019, 11:35 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I did a search but didn't see any posts showing the disassembly/reassembly/restoration of the female seat belt receivers. Mine are pictured below. I've ordered new stickers but would like to replate the screws on the back and the main steel portion (mine were very corroded where they bolt into the car; I put POR15 on them a couple of years ago but I'd rather disassemble, media blast and replate the whole thing). Any advice based on past experience with disassembly/reassembly would be much appreciated (as always).
FlacaProductions |
Dec 8 2019, 08:15 PM
Senior Member Group: Members Posts: 1,588 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@doug_b_928 and @Jett - just hold the mechanism in the same orientation that it is in the car so that the belt will release. Pull it ALL the way out and then grab the axle and push the belt back out thru the slot in the axle.
There is a pin that keeps the belt from pulling it back through - it slides out of the pocket in the belt and then (and this is important) WHILE STILL HOLDING THE AXLE AND PREVENTING IT FROM SPINNING, pull the belt back out of the slot. At this point, I used a small screw driver slipped thru the slot to keep the axle from spinning out. When you're ready, you can then grab the axle, remove the screwdriver and then start spinning the axle against the tension until it stop. Then back off half a turn or so and reinsert the belt and install the pin, pulling the belt tight back into the slot. Just be careful to not let the axle go as it'll spin out and release all tension. It's not a big deal and you can just spin it back again and all is well. While I had the the belt off, I removed all the hardware I could and washed the belt in some warm soapy water before hanging to dry and then reinstalling....just make sure you get the hardware on in the right orientation and order. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:24 PM |
