jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
What do I need to do to replace the plastic fuel lines? I searched this forum and the classics and didnt find anything on it. Does the engine need to be out? I'm assuming that the gas tank needs to be pulled. Any advice is appreciated
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
hahahaha wayno way!
jgiroux67 |
Thanks! I never even knew there was a info section.
Jakester |
lurking instead of working ![]() ![]() Group: Members Posts: 101 Joined: 18-May 05 From: Palo Alto, CA Member No.: 4,097 ![]() |
You can also contrast the 914Club article to the Pelican Parts Tech Article on replacing the center tunnel gas lines.
Different approaches - similar result. |
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
There is a Fuel Line Kit available in the 914 Resources, Parts and Products. I tried to copy the link, but it didn't work right.
Marv's3.6six |
Actual member 7" ![]() ![]() ![]() Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California ![]() ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I just did a great "fuel line mod" earlier today that I have to thank Jim Patrick (Patrick Motorsports) for the idea. His idea is to use a piece of 1" EMT electrical conduit and run it thru the tunnel from bulkhead to bulkhead, very easy todo.
It took less than an hour to do this, (my car is completely stripped right now) You just cut a hole at the rear after you remove the existing fuel lines, make the hole slightly larger than the 1" conduit, you will need to put a couple of very slight bends in the conduit so to follow the tunnel curve, cut a similar hole in the front bulkhead just push it into place from the rear, tack weld both ends, deburr the openings and you are done,you only need approx 4 feet of conduit. What this gets you is a solid pipe to run high pressure flexible fuel lines thru. If there is ever a break in the fuel line the 1" conduit is open only at the ends so there is no possible way for raw fuel to get in the cabin! |
smooth_eddy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 ![]() |
Hmmmm, this is a new twist. Seems like lots of people are re-doing their fuel lines. Can you post some photos? Was the motor in? What did you use for fuel lines? Eddy
Lo-Fi Version | Time is now: 18th July 2025 - 10:48 PM |
