bought original radio, 1974 914 1.8 |
brcacti |
Nov 17 2019, 06:05 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, I bought this radio in the pictures for my 74 914. Knobs center to center seem to be good with my small plate pictured here. BUT I will need to make it 1/4 inch wider on both sides to fit, any suggestions on how to cut it to make it look professional? Does anyone have a 4 inch wide plate to trade me? Mine is 3.5 inches wide.
914Sixer |
Nov 17 2019, 06:58 PM
914 Guru Group: Members Posts: 8,890 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Your bottom face plate is for a Motorola Sapphire radio. Top one is a single DIN. Here is what you need. Dash face plate and a radio face plate. Can do a straight up trade.
brcacti |
Nov 17 2019, 07:22 PM
WOW, thanks do you know anything about those Motorola sapphire radios? Are they fairly good? Will I need to buy some of the basket weave material for the metal plate? Know anyone who has a small piece?
brcacti |
Nov 17 2019, 07:23 PM
Also what is a single DIN?
brcacti |
Nov 17 2019, 07:26 PM
Also, it looks right, do you have the measurements for the rectangle width, height and knob center to center?
bbrock |
Nov 17 2019, 09:51 PM
Also what is a single DIN? Single DIN is a standard size for a car stereo height and width. The rectangular opening on your dash without any face or mounting plate over it is single DIN. Most modern cars have double DIN stereos that are twice the height of single DIN but the same width. |
JeffBowlsby |
Nov 17 2019, 11:22 PM
914 Wiring Harnesses Group: Members Posts: 8,515 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Sorry to have to say, but that radio is not correct for the 1974 model year. Its a later model better suited to the 1975-76, which I think is indicated in the SN code "76". Just because it not correct, does not mean it may not be OK for your car.
Mike Fitton |
Nov 18 2019, 07:38 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Automobile Atlanta has the correct 914 faceplate for this radio. The faceplate that Mark is showing is not correct installation for your radio although it will work.
http://www.autoatlanta.com/Porsche-Dashboa...55204010BA.html |
914Sixer |
Nov 18 2019, 08:55 AM
Mike is correct about face plate, was only trying to help find something to work.
DickSteinkamp |
Nov 18 2019, 09:30 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
DIN stands for Deutsches Institut für Normung, which is the German Standardization Institution that created the standard for head units used in cars today.
The ISO (International Standards Organization) adopted this DIN as ISO 7736, which is used by car manufacturers around the world. They are still called DIN radios because it was this German institute that invented the original standard. DIN 75490 standard specifies the dimensions for the unit when viewed from the front; it must be 180 x 50 mm. Single vs Double DIN Stereo |
brcacti |
Nov 18 2019, 01:36 PM
Sorry to have to say, but that radio is not correct for the 1974 model year. Its a later model better suited to the 1975-76, which I think is indicated in the SN code "76". Just because it not correct, does not mean it may not be OK for your car. Thanks Jeff, I don't see a Motorola sapphire radio for sale when I looked, saw one but it is probably MORE expensive and I ALREADY bought the other one. I did send off an email to the owner asking the price, it was not listed. Thanks for your information. |
brcacti |
Nov 18 2019, 01:38 PM
Your bottom face plate is for a Motorola Sapphire radio. Top one is a single DIN. Here is what you need. Dash face plate and a radio face plate. Can do a straight up trade. THANKS 914 Sixer.........I do like your set up for the radio I bought and am leaning to do the trade. Can you send measurements so I can verify the fit? Redio rectangle width, height and knob spacing center to center? Would be appreciated. |
914Sixer |
Nov 18 2019, 09:43 PM
Reply sent
Rob-O |
Nov 19 2019, 08:42 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Does that black trim around the dial indicator come off? Because I thought they did.
If so, I have a plate for you. Mark sent me what I needed last week for MY radio project. The one I have is a little thicker than the ones that came in our cars when the dealers installed radios. But it is freshly covered. The opening is 3.75” wide. If the black trim was removed your dial indicator may be 3.75” instead of the 4” you mentioned above. Yours for the asking... Not trying to step on Marks offer. Just trying to pay his good deed to me forward... Attached thumbnail(s) |
Mike Fitton |
Nov 19 2019, 09:31 AM
Does that black trim around the dial indicator come off? Because I thought they did. If so, I have a plate for you. Mark sent me what I needed last week for MY radio project. The one I have is a little thicker than the ones that came in our cars when the dealers installed radios. But it is freshly covered. The opening is 3.75” wide. If the black trim was removed your dial indicator may be 3.75” instead of the 4” you mentioned above. Yours for the asking... Not trying to step on Marks offer. Just trying to pay his good deed to me forward... That will not work with the OP radio. |
dr914@autoatlanta.com |
Nov 19 2019, 10:10 AM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wow exact same radio that came in my 76 914 years ago. We make the proper plates.
914Sixer |
Nov 19 2019, 11:08 AM
Right now NO one is making the correct thickness plates. Read my past threads.
brcacti |
Nov 19 2019, 02:33 PM
Hello, I bought this radio in the pictures for my 74 914. Knobs center to center seem to be good with my small plate pictured here. BUT I will need to make it 1/4 inch wider on both sides to fit, any suggestions on how to cut it to make it look professional? Does anyone have a 4 inch wide plate to trade me? Mine is 3.5 inches wide. THANKS to EVERYONE, I think me and 914sixer have this figured out |
enoz05 |
Apr 11 2020, 03:03 AM
Newbie Group: Members Posts: 11 Joined: 24-May 17 From: Europe Member No.: 21,126 Region Association: Europe |
Prefix "K" correct for 1977
Lo-Fi Version | Time is now: 24th May 2024 - 02:17 PM |
