No Serial Number on Front Clip |
bkrantz |
Nov 17 2019, 10:27 PM
914 Guru Group: Members Posts: 7,768 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I cleaned paint and other crud to expose the serial number on the right front inner fender, but somebody removed it with a grinder. Is this standard procedure? All I can say is the the donor car was originally non-metallic green.
Attached thumbnail(s) |
sixnotfour |
Nov 17 2019, 10:36 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
wire wheel the back side..you can get a ghost image ..
http://www.914world.com/bbs2/index.php?sho...8239&st=20# |
SirAndy |
Nov 17 2019, 10:56 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is this standard procedure? For criminals, yes. Otherwise, no. (IMG:style_emoticons/default/popcorn[1].gif) |
Chi-town |
Nov 18 2019, 12:42 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Looks like it was welded and ground down. I've seen a few cars where Body shops have done this when the put a complete clip on a car. Usually they will restamp the original vin though.
Cairo94507 |
Nov 18 2019, 08:40 AM
Michael Group: Members Posts: 9,771 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Sorry, but I have only ever seen that associated with stolen cars or car parts. I hope you can pull an image off the back side to see the VIN. That is frustrating. (IMG:style_emoticons/default/beerchug.gif)
914Sixer |
Nov 18 2019, 08:52 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Could be as simple as it never got stamped, if nothing shows up on the bottom side.
SirAndy |
Nov 18 2019, 01:23 PM
Could be as simple as it never got stamped, if nothing shows up on the bottom side. Not stamped? As in, not stamped from the factory or not stamped as in a unstamped factory original replacement panel? Also, why would they have to take the grinder to the top if it was never stamped? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:46 PM |
