It's on PMs sent -GB for Trailing Arm bushings Rubber and option for Urethane, Who's interested? 4 pcs (one car) $28 a set rubber $36 Poly |
Mikey914 |
Nov 18 2019, 04:08 PM
The rubber man Group: Members Posts: 12,653 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are in the process of doing the A arm bushings in rubber
We can easily do these up in a polyurethane at the same time, just have to do enough to pay for the materials and set up would be looking at 25 sets to do the Poly The GB would be for a set of 4 (enough for 1car) For $28 in rubber and $36 in poly To get the pricing right we need 40 takers in rubber and 25 in Poly We've been in testing on these for some time and had made a couple variations. This is what they look like. SO Who's in? Attached image(s) |
yellowporky |
Nov 18 2019, 06:50 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
do you mean trailing arm bushings? I already bought the kit so will the shaft be the same? Will these squeak after a while?
Thanks |
Mikey914 |
Nov 18 2019, 09:04 PM
do you mean trailing arm bushings? I already bought the kit so will the shaft be the same? Will these squeak after a while? Thanks The shaft kit will be the same. The stainless is bulletproof. I was amazed to see the factory was a hollow tube and the welds were not great. So water got in the inside and rusted. |
Lo-Fi Version | Time is now: 6th May 2024 - 03:25 AM |
