It's on PMs sent -GB for Trailing Arm bushings Rubber and option for Urethane, Who's interested? 4 pcs (one car) $28 a set rubber $36 Poly |
Mikey914 |
Nov 18 2019, 04:08 PM
The rubber man Group: Members Posts: 12,653 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are in the process of doing the A arm bushings in rubber
We can easily do these up in a polyurethane at the same time, just have to do enough to pay for the materials and set up would be looking at 25 sets to do the Poly The GB would be for a set of 4 (enough for 1car) For $28 in rubber and $36 in poly To get the pricing right we need 40 takers in rubber and 25 in Poly We've been in testing on these for some time and had made a couple variations. This is what they look like. SO Who's in? Attached image(s) |
Mark Henry |
Nov 21 2019, 08:59 PM
Not sure if I want rubber or poly? new shafts? (IMG:style_emoticons/default/confused24.gif)
This is about the only job I haven't done because I don't have any issues. If you do poly is there a way of adding grease fittings? I have Full Motion (needle bearings) on the fronts. Hot street car only, I might do a DE now that I'm a PCA member. |
Mark Henry |
Nov 21 2019, 09:07 PM
I can't find the shaft on your site (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 5th May 2024 - 11:55 PM |
