AAR valve, Is it possible to repair |
Ian Stott |
Nov 18 2019, 04:17 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Having trouble sourcing a new or good used AAR valve, all help much appreciated. Can they be reconditioned?
Ian Stott Moncton Canada |
jcd914 |
Nov 19 2019, 05:09 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Check it with a vacuum pump at the small nipple and see if it holds vacuum and whether the valve opens when you apply vacuum.
They have a rubber diaphragm so you need to be careful what you use to try to clean them as some solvents or oils will break down the rubber. Put a WTB ad in the classifieds, there are working used one out there. Jim |
Lo-Fi Version | Time is now: 19th May 2024 - 05:42 AM |
