Considering migrating from a Miata... am I crazy? |
fuzzybeanbag |
Nov 21 2019, 03:17 AM
Newbie Group: Members Posts: 2 Joined: 21-November 19 From: CA Bay Area Member No.: 23,660 Region Association: Northern California |
Hi all,
First - sorry ahead of time if you've seen a million of these posts... I currently own a rare-ish 95 M Edition Miata (the purple one); low mileage, exceptionally maintained, race suspension bla bla, etc. It is a fun car, a weekend tosser if you will, and the 2nd one I've owned so I know my way around Miatas. Recently, I've been looking around 914s in the CA Bay Area, a car that I've always liked (and only because if the flip-up headlights)... and come across a couple that are priced fairly well and appear to be fairly restored, at least cosmetically. But - I am a stranger to aircooled drivetrains, my familiarity with VAGs is limited to MK6 GTI, B7 Passats, C7 A6 TDI and B8.5 A4s... so fancy modern cars. What am I potentially getting myself into? I am good with a screwdriver and a hammer; can even handle a wire stripper and a soldering iron... But in the years I've owned my Miata, aside from the occasional oil change, brake pad/rotor maintenance, and tightening of a slightly leaky oil pan drain plug, I had to do zero work on the car... ... it also has a working A/C. Thanks in advance! (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/sheeplove.gif) |
RARE 6 |
Nov 22 2019, 06:30 PM
Member Group: Members Posts: 141 Joined: 18-January 15 From: Grand Junction CO Member No.: 18,337 Region Association: Rocky Mountains |
Or you could just put pop-up headlights on your Miata. Probably cheaper in the long run.
914forme |
Nov 24 2019, 12:21 PM
Or you could just put pop-up headlights on your Miata. Probably cheaper in the long run. (IMG:style_emoticons/default/av-943.gif) Early chassis which his 95 is has pop up head lights. The M-Editions will be most likely the most collectible of the early Miatas. Mine they made a bit over 2000, that is 914-6 territory. But factory rare color cars will most likely be the top dogs. But they lack a bit of soul. Fun, but soulless. I am selling my Miata M edition, I am keeping my 914-6. Other cars will come and go, the 914-6 will stay. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:47 AM |
