Small matter - resetting Trip Odometer |
Gatornapper |
Nov 21 2019, 07:50 AM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
A very small matter, but I want everything working on my 914, and this is one of the last items: the reset thingy for the Trip Odometer used to work, but no longer does.
Cannot remember if you turn it or push it in - either way does nothing. If I push it in, it stays up in the cable for a while before dropping down again.... Is this something easily fixed? Do not want to replace ODO as it is original with original 61k miles on it...... TIA, GN |
mepstein |
Nov 21 2019, 07:57 AM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You turn it clockwise. Never while the car is moving. There is a small plastic gear that comes loose on the shaft. It can be repaired without losing milage or replacing. They often go bad around 80K.
I think the "how to" is listed on pelican and there are threads on world as well. Not a hard DIY project. |
Gatornapper |
Nov 21 2019, 08:53 AM
Thanks!
You turn it clockwise. Never while the car is moving. There is a small plastic gear that comes loose on the shaft. It can be repaired without losing milage or replacing. They often go bad around 80K. I think the "how to" is listed on pelican and there are threads on world as well. Not a hard DIY project. |
Lo-Fi Version | Time is now: 29th April 2024 - 09:56 AM |
