Identify this cable |
surfdogskier |
Nov 21 2019, 10:34 AM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
When I was installing my new fuel pump under my car, I noticed this cable wasn't connected to anything. I have no idea what it is or where it goes. Any ideas? Thanks!
Attached thumbnail(s) |
dlee6204 |
Nov 21 2019, 10:36 AM
It goes to one of two heater valves that control heat to the cab. These valves are mounted to the heat exchangers right before the opening to the longitudinal.
rhodyguy |
Nov 21 2019, 10:37 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Heat valve control wire.
ctc911ctc |
Nov 21 2019, 12:06 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I politely suggest to change your gas lines to Stainless, looks like legacy lines (on the right) which have been known to leak and cause burn-downs.
Suggestion only.......ask me why I am writing this (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/blink.gif) When I was installing my new fuel pump under my car, I noticed this cable wasn't connected to anything. I have no idea what it is or where it goes. Any ideas? Thanks! |
surfdogskier |
Nov 21 2019, 06:39 PM
surfdogskier |
Nov 21 2019, 06:40 PM
I politely suggest to change your gas lines to Stainless, looks like legacy lines (on the right) which have been known to leak and cause burn-downs. Suggestion only.......ask me why I am writing this (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/blink.gif) When I was installing my new fuel pump under my car, I noticed this cable wasn't connected to anything. I have no idea what it is or where it goes. Any ideas? Thanks! I eventually want to do that. I want to get a car lift installed and that would be one of my first things to do. |
Lo-Fi Version | Time is now: 9th May 2024 - 05:06 PM |
