Tire Savers |
Tire Savers |
Minerva's 914 |
Nov 25 2019, 04:24 AM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
Started looking online for a set of tire savers to park the 914 and the prices range from $19.99 to $250 and many of the mid range items vary in price as much as $60 for what appears to be the exact same set. Any of you guys use them? Do they help protect the tires from becoming flat spotted? Any experience with certain brands being better than others? I've also thought of putting the car on jack stands to receive the weight on the tires but not so high that the suspension is fully extended.
Yeah, I know ..... just drive the car. |
Superhawk996 |
Nov 25 2019, 05:22 AM
914 Guru Group: Members Posts: 5,784 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Started looking online for a set of tire savers to park the 914 and the prices range from $19.99 to $250 and many of the mid range items vary in price as much as $60 for what appears to be the exact same set. Any of you guys use them? Do they help protect the tires from becoming flat spotted? Any experience with certain brands being better than others? I've also thought of putting the car on jack stands to receive the weight on the tires but not so high that the suspension is fully extended. Yeah, I know ..... just drive the car. Jack stands. |
Racer |
Nov 25 2019, 08:02 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I just put "extra" air in mine (30-32psi all around).
imho, as long as there is no salt on the pavement, wake her up and drive her during the winter. |
Minerva's 914 |
Nov 25 2019, 08:32 AM
Started looking online for a set of tire savers to park the 914 and the prices range from $19.99 to $250 and many of the mid range items vary in price as much as $60 for what appears to be the exact same set. Any of you guys use them? Do they help protect the tires from becoming flat spotted? Any experience with certain brands being better than others? I've also thought of putting the car on jack stands to receive the weight on the tires but not so high that the suspension is fully extended. Yeah, I know ..... just drive the car. Jack stands. Thanks for the feedback, and I'm proud to have been the recipient of your 1000th post. (IMG:style_emoticons/default/first.gif) |
Minerva's 914 |
Nov 25 2019, 08:34 AM
jvmarino |
Nov 25 2019, 01:02 PM
Member Group: Members Posts: 80 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
I like to up the pressure for storage as well. I also like to push the car a bit forward/backward every month or so, so the resting spot of the tire moves.
Superhawk996 |
Nov 25 2019, 07:24 PM
Modern tires are more prone to flat spotting. The intermittent drives help more than the intermittent rolling which just serves to add more flat spots.
Depending on tire construction and rubber compound, you can get permanent changes in radial tire forces in as little as a month. Jack stands are the sure fire way to avoid flat spots all together but you can balance the risk with the intermittent drives since your winters will allow that. |
Garland |
Nov 25 2019, 09:20 PM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
I just put "extra" air in mine (30-32psi all around). imho, as long as there is no salt on the pavement, wake her up and drive her during the winter. (IMG:style_emoticons/default/agree.gif) just takes a few more cranks to fire up in the cool weather, and off you go! |
Minerva's 914 |
Nov 25 2019, 11:02 PM
Yeah, I like the idea of rotating the tires on pavement (as in driving it), hey it's NC. Don't like the weather, hang around a couple weeks.
I do think I'll pass on the tire savers, increase the pressure and for any extended parking I'll lift the car enough to receive the pressure on the tires. |
Superhawk996 |
Nov 26 2019, 05:47 AM
I just put "extra" air in mine (30-32psi all around). imho, as long as there is no salt on the pavement, wake her up and drive her during the winter. (IMG:style_emoticons/default/agree.gif) just takes a few more cranks to fire up in the cool weather, and off you go! @Garland Seriously? Are you driving that nice of a car on Michigan's salty, winter pot-holed roads? My hat's off to you. When I had my original 914 it went into storage piror to 1st salt and then didn't come out until after the 1st couple spring rains had washed away the salt. I used to buy $100-$200 "winter beater" cars to get though the slushy months. (IMG:style_emoticons/default/rolleyes.gif) Things like worn out VW bugs, Datsun 510's, Chevy Caprice Classic. It really made me appreciate spring and the 914! |
Garland |
Nov 26 2019, 10:18 AM
I avoid the “bad” roads, and never drive it on the salty slushy days. But when the roads dry (some salt dust only), or before the salt trucks make there pass, it’s a blast in the snow.
Charles Freeborn |
Nov 26 2019, 10:28 AM
Member Group: Members Posts: 248 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
I keep mine on "skates" I got from Harbor Freight. Lets me roll it around in the garage too. Adding some extra air is a good idea, and yes, drive or at least run it no less than once per month.
Lo-Fi Version | Time is now: 10th May 2024 - 11:05 AM |
