Another "S" bites the dust |
wndsrfr |
Nov 25 2019, 01:51 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Exiting the bus stop at Daytona firmly in 4th gear put the power to it and POP...
Here's the carnage... Attached thumbnail(s) |
Krieger |
Nov 26 2019, 10:22 AM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have one mod that a racer engine builder John William's at Otto's in Venice beach told me I must have. He said the rear studs that hold the tail cone work loose under load. The higher power is loosening the nuts/studs that hold the tail cone. He had me install longer studs (the ones that hold the tail cone on). Make them so they protrude through the forward end of the trans case. Put nuts on the studs as they are coming through. Tighten the nuts. Then weld those nuts to the studs. I have recently added an oil cooler.
wndsrfr |
Nov 26 2019, 03:39 PM
I have one mod that a racer engine builder John William's at Otto's in Venice beach told me I must have. He said the rear studs that hold the tail cone work loose under load. The higher power is loosening the nuts/studs that hold the tail cone. He had me install longer studs (the ones that hold the tail cone on). Make them so they protrude through the forward end of the trans case. Put nuts on the studs as they are coming through. Tighten the nuts. Then weld those nuts to the studs. I have recently added an oil cooler. Now that's great advice on strengthening the studs...cooler may be in the works later if I'm running more than sprint sessions.... |
Lo-Fi Version | Time is now: 17th May 2024 - 04:08 AM |
