Six Header Id |
Six Header Id |
G e o r g e |
Nov 26 2019, 08:47 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
mb911 |
Nov 27 2019, 05:37 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Bursch i believe
Maltese Falcon |
Nov 27 2019, 09:37 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Bursch...available through a dealer network ¿? (IMG:style_emoticons/default/blink.gif)
ClayPerrine |
Nov 27 2019, 10:21 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That's what I have on Igor. I am disappointed with them. The right muffler flange is 2"" lower than the left.
I am going to be running them until I can get some heat exchangers with 1.75 primaries. |
Maltese Falcon |
Nov 27 2019, 11:35 PM
Clay...did you cut/paste/reweld the Bursch problem, I wouldn't think that you could mount anything that caddywhompass ¿¿
mb911 |
Nov 28 2019, 06:23 AM
ClayPerrine |
Nov 28 2019, 10:29 AM
That's what I have on Igor. I am disappointed with them. The right muffler flange is 2"" lower than the left. I am going to be running them until I can get some heat exchangers with 1.75 primaries. I am interested in doing these for you at some point. Cool! They will have to be slightly lower than the stock HEs. The right CV joint is touching the current header with the suspension at full droop. I also have to figure out how to put a muffler other than the Supertrapps on them. Funny.. at the last AX, I had 3 different teenagers ask how the exhaust got out of the muffler.. (IMG:style_emoticons/default/av-943.gif) |
sixnotfour |
Nov 28 2019, 11:56 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE a muffler other than the Supertrapps on them (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif) unleash the beast.... |
mb911 |
Nov 28 2019, 12:29 PM
That's what I have on Igor. I am disappointed with them. The right muffler flange is 2"" lower than the left. I am going to be running them until I can get some heat exchangers with 1.75 primaries. I am interested in doing these for you at some point. Cool! They will have to be slightly lower than the stock HEs. The right CV joint is touching the current header with the suspension at full droop. I also have to figure out how to put a muffler other than the Supertrapps on them. Funny.. at the last AX, I had 3 different teenagers ask how the exhaust got out of the muffler.. (IMG:style_emoticons/default/av-943.gif) Is your current setup like the factory setup? |
ClayPerrine |
Nov 29 2019, 07:48 AM
Is your current setup like the factory setup? I have the exact same headers that are pictured in this thread. If you look at this picture, you can see the triangle shaped collector, and how close it is to the CV boot. When the car is sitting on the ground, the cv boot is not touching. And that is after I beat a dent into the header with a ball peen hammer to make sure it will clear. Yours use a flat collector, so I think it will be less of an issue, but this is all custom so you never know. That's why I think the HE will have to be slightly lower. |
mb911 |
Nov 29 2019, 08:07 AM
Ideally a f1 merge collector would be more ideal for your application..
ClayPerrine |
Nov 29 2019, 08:56 AM
IronHillRestorations |
Nov 29 2019, 09:31 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Horsepower Engineering - AKA Bursch. I ran into interference with Bursch headers on a stock 914-6, one of the tubes hit the oil cooler and could not be bolted up. I contacted them, sent pictures, got the "we want to make them fit right". So I sent the "bad" one to them at my expense, 14 months later still hadn't gotten it back, I called and they said, "sorry we just never got to it" and sent it back to me. That was the last Bursch I purchased.
Ben or Marty is who you want to make your exhaust. |
mb911 |
Nov 29 2019, 09:52 AM
Horsepower Engineering - AKA Bursch. I ran into interference with Bursch headers on a stock 914-6, one of the tubes hit the oil cooler and could not be bolted up. I contacted them, sent pictures, got the "we want to make them fit right". So I sent the "bad" one to them at my expense, 14 months later still hadn't gotten it back, I called and they said, "sorry we just never got to it" and sent it back to me. That was the last Bursch I purchased. Ben or Marty is who you want to make your exhaust. Thanks Perry for the kind words |
gandalf_025 |
Nov 29 2019, 11:08 AM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
How many of you have seen a set like this before ...???
I know I have posted pictures of them here at one time |
mb911 |
Nov 29 2019, 11:47 AM
gandalf_025 |
Nov 29 2019, 11:57 AM
Yes, these were a backup set from Ralph Meaney's
Stash. I bought them in the mid 70’s . |
Mark Henry |
Nov 29 2019, 12:40 PM
Ben or Marty is who you want to make your exhaust. (IMG:style_emoticons/default/agree.gif) But I'd also add tangerine for /4 headers I have Marty's MSDS coated headers on my /6, they are beautiful and fit without issues. Someday I'll get Ben's heat exchangers for heat. I also have a /4 tangerine 1-7/8" coated set hanging on the wall here...just need to find a home for them. |
Maltese Falcon |
Nov 29 2019, 04:22 PM
Ben or Marty is who you want to make your exhaust. (IMG:style_emoticons/default/agree.gif) But I'd also add tangerine for /4 headers I have Marty's MSDS coated headers on my /6, they are beautiful and fit without issues. Someday I'll get Ben's heat exchangers for heat. I also have a /4 tangerine 1-7/8" coated set hanging on the wall here...just need to find a home for them. Thank you Perry & Mark for the kind mention ¡ We mfg and stock the 1.75" od 9146 headers for the 3.6L + up conversions. Clay ...I'm sure that Ben or I can put something together (with clearence) for your NFG headers that you are running at present. |
Mark Henry |
Nov 29 2019, 04:35 PM
Here's some upskirt MSDS header porn. (IMG:style_emoticons/default/drooley.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-26-1497650959_thumb.jpg) |
Lo-Fi Version | Time is now: 14th May 2024 - 10:37 AM |
