FS 914-6, 914 Headlight Pivot Bracket set with new install hardware, SOLD :Bracket set $80 - New backing plates and hardware $25 a set |
bdstone914 |
Nov 30 2019, 10:59 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
EDIT: brackets sold, several sets of plates available.
This is a set of restored early solid steel brackets used in Early 1970-1972? cars. The pivot brackets are one pieces cast steel. The later brackets were cast zinc a with a steel pivot shaft pin inserted. Later ones are more prone to breaking. These are correct for a 914-6. New steel packing plates were laser cut and zinc plated. New allen head screws and flat washers included. I do need to add lock washers for these which are not in the picture. You will need new bushings which are carried by 914Rubber. Bracket set with plates and hardware $80 shipped - one set available Plate set with allen screws and washers $25 shipped - several sets available Attached thumbnail(s) |
live free & drive |
Nov 30 2019, 01:11 PM
Member Group: Members Posts: 156 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
I'll take the two sets, PM sent
Nov 30 2019, 02:34 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You also can't plate the late ones. Ask me how I know. (IMG:style_emoticons/default/headbang.gif)
bdstone914 |
Nov 30 2019, 03:34 PM
@live free & drive
date='Nov 30 2019, 01:11 PM' post='2766416'] I'll take the two sets, PM sent [/quote] To clarify, the two sets are what is pictured and enough for one car. Two inside and two outside with backing plates and hardware. I take paypal at bdstone914@aol.com Do not send as friends and family. Thanks Bruce |
bdstone914 |
Nov 30 2019, 03:36 PM
@mepstein date='Nov 30 2019, 02:34 PM' post='2766431']
You also can't plate the late ones. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) [/quote] Have you tried to plate 911 the deck lid lock plunger ? Same result. You cant zinc plate zinc. |
Nov 30 2019, 04:06 PM
[quote name='bdstone914' date='Nov 30 2019, 04:36 PM' post='2766445']
@mepstein date='Nov 30 2019, 02:34 PM' post='2766431'] You also can't plate the late ones. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) [/quote] Have you tried to plate 911 the deck lid lock plunger ? Same result. You cant zinc plate zinc. [/quote] I only plate my stuff, so no 911 parts. I can also tell you not to plate the 914 rear trunk lock receiver - wasted 3 of those, and the pull handle for the front trunk release. I have had good luck powder coating the front trunk release handle. The trick is to go very light on the powder. Just enough to cover without much thickness. Cerikote would be good on that also. |
bdstone914 |
Nov 30 2019, 05:01 PM
@mepstein' date='Nov 30 2019, 04:06 PM' post='2766457']
[quote name='bdstone914' date='Nov 30 2019, 04:36 PM' post='2766445'] @mepstein date='Nov 30 2019, 02:34 PM' post='2766431'] You also can't plate the late ones. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) [/quote] Have you tried to plate 911 the deck lid lock plunger ? Same result. You cant zinc plate zinc. [/quote] I only plate my stuff, so no 911 parts. I can also tell you not to plate the 914 rear trunk lock receiver - wasted 3 of those, and the pull handle for the front trunk release. I have had good luck powder coating the front trunk release handle. The trick is to go very light on the powder. Just enough to cover without much thickness. Cerikote would be good on that also. [/quote] Good idea to put a magnet to any parts to be plated. Stainless does not plate well either. Tends to blister. I have had some zinc parts gas put when powder coated bubbling the paint. I know a guy with some new rear trunk latches. (IMG:style_emoticons/default/poke.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 05:59 AM |
