FS Full 5 lug Conversion Kit With Boxster Front Calipers, SOLD |
tazz9924 |
Dec 1 2019, 04:44 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Hello world im finally in the position to sell my big ticket item. I have for everyone 911 carrera koni front struts and hubs. Theres a couple negatives to these; the shock on one is bent but the tube it sits in is still dead straight. Put a new shock in and it is good to go. They are koni red shocks and i found them new on summit/ tire rack when i bought them ~5000 miles ago. And the other negative is at one point the other strut rubbed off the threads on the inside so part of it was cut off and a new section was tigged back on. It is perfectly functional and you cant see it anyway. They also need paint (IMG:style_emoticons/default/laugh.gif) This also comes with boxster front calipers, rebel racing adapters and braided brake lines, rear 5 lug redrilled hubs and rotors, and bilstein rear struts with 120 or 140lb rear springs. Other than the bent shock everything works great, most things have new bits, the calipers were used, the rotors are 24mm and they also have about 5000 miles. The rear rotors also have about 5000 miles, ill remove the rear hubs and rotors when i get a chance (if you need i can also send the stock rear calipers). I was daily driving this setup and would continue doing such but my car got hit. If you have any questions let me know. I will split it up. $1000 plus shipping
tazz9924 |
Dec 3 2019, 08:01 AM
Bump $1100
tazz9924 |
Dec 5 2019, 06:46 AM
$1000 bump
tazz9924 |
Dec 6 2019, 08:44 PM
Will now Split up!
bdstone914 |
Dec 6 2019, 11:35 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
tazz9924 |
Dec 7 2019, 05:21 PM
rear shocks pending
N8T914 |
Dec 7 2019, 06:19 PM
Newbie Group: Members Posts: 4 Joined: 21-November 19 From: Santa Barbara Ca Member No.: 23,662 Region Association: Southern California |
PM sent
tazz9924 |
Dec 8 2019, 12:32 PM
Everything is sold! thanks guys (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 03:52 AM |
