123ignition install problem with stabbing it into shaft groove |
9144me2enjoy |
Dec 4 2019, 03:57 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Question maybe you can help me out. I’m in the process of putting a 123ignition in my 914 1.8. The original ignition/distributor came out with no problem. I slid the spacer on the shaft first then the locking ring but I’m having a hard time getting the shaft to drop down in the hole into the slots/groove. I have moved the rotor around where it looks like its lined up with the groove in the bottom of the shaft and put grease on the shaft and o-ring. What am i doing wrong? Thanks
I was able to get it to finally drop in by leaving off the spacer! I’m not sure how important the spacer is on this application? Attached thumbnail(s) |
rjames |
Dec 4 2019, 04:39 PM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
You need the spacer to engage the distributor.
It took a bit of force (nothing drastic!) to get mine to seat. Make absolutely sure you have it lined up properly. Reinstall your old distributor, remove it and make note of how the bottom lines up and try again. |
9144me2enjoy |
Dec 4 2019, 04:59 PM
Thanks, I was able to get the distributor stabbed finally! Did you end up using the blue wire? I know since the 914s are Negative ground therefore the black wire goes to the - post on the coil and the red wire goes to the + post on the coil. But not sure if or where the Blue wire goes in my application. (Carbs not FI). Found out it connects to the negative post on the battery. Thanks
Lo-Fi Version | Time is now: 5th May 2024 - 05:07 PM |
