Door lock help, Doesn't work 100% |
screenguy914 |
Dec 5 2019, 04:52 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Need assistance with my passenger door before I tear into the door.
Able to lock/unlock from the inside and outside with the key Interior and exterior door release handles operate However, when locking with the key, it rotates only about 10 degrees, then stops. I should be satisfied, but I fear it might get worse. Is this an issue with the key tumbler or with the exterior door handle mechanism? Thanks |
Mark Henry |
Dec 5 2019, 07:58 PM
Just did this on the passenger side for a broken cam, a bit of a PITA if you have big mitts, but a fairly straight forward job.
I just did my passenger side, now it's obvious the left side needs doing as well. I found a better handle but I had to drill out the rivet and tap for an M6 bolt and swap the lockset. This handle already had a good original cam so I left it in and cleaned and lubed the rest. If you pull the lockset just take care that you don't let the wafers fall out. The lock mechanism does come out without removing other stuff, I had to turn it 180 around the window track, but it did sneak out. The old grease had mixed with dirt that turned it into cement. Now it works and locks excellent and I don't have to worry about locking myself out. |
mepstein |
Dec 5 2019, 08:09 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just did this on the passenger side for a broken cam, a bit of a PITA if you have big mitts, but a fairly straight forward job. I just did my passenger side, now it's obvious the left side needs doing as well. I found a better handle but I had to drill out the rivet and tap for an M6 bolt and swap the lockset. This handle already had a good original cam so I left it in and cleaned and lubed the rest. If you pull the lockset just take care that you don't let the wafers fall out. The lock mechanism does come out without removing other stuff, I had to turn it 180 around the window track, but it did sneak out. The old grease had mixed with dirt that turned it into cement. Now it works and locks excellent and I don't have to worry about locking myself out. The wafers will stay in if you keep a key in the lock. Doesn’t even have to be the correct key, any Porsche key should work. |
TheCabinetmaker |
Dec 7 2019, 09:13 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just did this on the passenger side for a broken cam, a bit of a PITA if you have big mitts, but a fairly straight forward job. I just did my passenger side, now it's obvious the left side needs doing as well. I found a better handle but I had to drill out the rivet and tap for an M6 bolt and swap the lockset. This handle already had a good original cam so I left it in and cleaned and lubed the rest. If you pull the lockset just take care that you don't let the wafers fall out. The lock mechanism does come out without removing other stuff, I had to turn it 180 around the window track, but it did sneak out. The old grease had mixed with dirt that turned it into cement. Now it works and locks excellent and I don't have to worry about locking myself out. The wafers will stay in if you keep a key in the lock. Doesn’t even have to be the correct key, any Porsche key should work. I have a 2000 Chevy Astro van. Yesterday l accidentally inserted my 914 ignition key in the van. It slipped in perfectly, but, of course, wouldn't turn. I thought what the hell, till l figured out i had the wrong key. After comparing the two keys, l found out they are almost identical. Going to see if l can rekey a lock cylinder to the Chevy key. |
Lo-Fi Version | Time is now: 16th May 2024 - 04:31 PM |
