Door lock help, Doesn't work 100% |
screenguy914 |
Dec 5 2019, 04:52 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Need assistance with my passenger door before I tear into the door.
Able to lock/unlock from the inside and outside with the key Interior and exterior door release handles operate However, when locking with the key, it rotates only about 10 degrees, then stops. I should be satisfied, but I fear it might get worse. Is this an issue with the key tumbler or with the exterior door handle mechanism? Thanks |
dr914@autoatlanta.com |
Dec 7 2019, 10:31 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
my immediate call would be to clean the catching mechanism they get dirty and disallow the key from turning far enough to unlock or lock the door. Eventually the end of the lock cylinder breaks off from too much force exerted. Read all about it in the 914 "Tech Tips 700"
Need assistance with my passenger door before I tear into the door. Able to lock/unlock from the inside and outside with the key Interior and exterior door release handles operate However, when locking with the key, it rotates only about 10 degrees, then stops. I should be satisfied, but I fear it might get worse. Is this an issue with the key tumbler or with the exterior door handle mechanism? Thanks |
Lo-Fi Version | Time is now: 16th May 2024 - 01:05 PM |
