Additional air valve electric power consumption ?, can it hinder the startup ? |
CheeRS |
Dec 7 2019, 03:54 PM
Member Group: Members Posts: 93 Joined: 5-May 19 From: Paris France Member No.: 23,093 Region Association: France |
Bonsoir,
in january I will do a three-days rally race in the snow in the coldest region of France and the coldest in Europe, the record is -46C. The starts are difficult. On my 914 I had found the electric wire from the additional air valve plugged out. keeping in mind the car ran before I was the owner of the historic Monte Carlo Rally (in winter and the snow)I asked myself if this wire was unplugged to save start power . Do you how may Ampere this valve ask for ? Could I imagine a system with a switch to turn it off at the starting and just after put it on to warm and close slowly the additional air flow ? Thanks CheeRs |
Mikey914 |
Dec 7 2019, 04:19 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Any power saved would be minuscule. I'd try plugging it in if you have enough time and see what the difference is. I would suspect it would start easier.
porschetub |
Dec 7 2019, 04:52 PM
Can you confirm it is working? ,it may have been sticking open so wasn't connected ,the one I recently tested didn't stay open for long,power it up and see if you can blow thru it,power to wire and ground to mounting bracket
They can be cleaned without pulling apart,pretty simple part really but you need to retain it. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:51 PM |
