Bleed injection? Newby to FI and 914s |
Robson51 |
Dec 7 2019, 06:38 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
We removed and cleaned the fuel tank in my son's new to him 914. Also changed the fuel lines to stainless steel. Other than setting valves, nothing mechanical or electrical was done. Ran fine when parked a month ago.
He tried to start the car and nothing. I'm suspecting fuel, but I am new to fuel injection and don't know where to start, except to see that fuel is reaching the fuel pump. (I'm a webers on 912 guy) Does the injection system have to be bled when it has been reduced to bone dry empty like this? How is that done? A search of the threads has turned up nothing. This will be tomorrow's project. Thanks- Rob |
dlee6204 |
Dec 7 2019, 06:41 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
No bleeding necessary. First I would check to see if you’re building fuel pressure. If not I would expect the fuel lines to have been crossed or a kinked line under the tank.
PanelBilly |
Dec 7 2019, 06:48 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Welcome to the group
BeatNavy |
Dec 7 2019, 06:49 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I agree, no bleeding required. Which FI is this? 914's stock FI was either D-Jet (1.7 and 2.0 liter cars) or L-Jet (1.8). While they are very similar in many ways, there are unique aspects to each that need to be understood. It can also help us help you troubleshoot.
FI is not hard to understand and it works great -- but all the little pieces need to be there and working properly. Sometimes that is hard on a 45+ year old car. |
TheCabinetmaker |
Dec 7 2019, 08:34 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Fuel lines in engine bay are crossed
Chris914n6 |
Dec 7 2019, 08:46 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You should be able to cycle the fuel pump a few times and hear burping in the tank.
Robson51 |
Dec 7 2019, 11:12 PM
Thanks everyone! It's a '74 2.0. I'll dig into it tomorrow and see what happens!
Rob |
Specracer |
Dec 8 2019, 06:33 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
The reason you dont need to bleed is that there is a return path, self bleeding.
My story, I have a 1.7, the PO moved the 3 port pump up to the front. Before the year or so restoration I have been doing, I got the car running in this configuration. Fast forward to some period of time during reassembly, I re plumed, the 3 port (all new lines), wont run. Note when I got the car initially running, I took the pump apart, cleaned it, and even bench tested and ran it. I have no idea what happened to the 3 port, during the year of sitting, but I cut my losses and switched to a new 2 port, re plumed, and now it runs again. |
BeatNavy |
Dec 8 2019, 06:34 AM
Thanks everyone! It's a '74 2.0. I'll dig into it tomorrow and see what happens! Rob Cool, we'll assume it's D-Jet then. Although your issue right now may be as simple as crossed fuel lines as suggested, you may want to start reading to get up to speed on your FI. This is a very helpful resource: https://members.rennlist.com/pbanders/ Good luck (IMG:style_emoticons/default/beerchug.gif) |
Chris914n6 |
Dec 8 2019, 11:28 AM
The reason you dont need to bleed is that there is a return path, self bleeding. My story, I have a 1.7, the PO moved the 3 port pump up to the front. Before the year or so restoration I have been doing, I got the car running in this configuration. Fast forward to some period of time during reassembly, I re plumed, the 3 port (all new lines), wont run. Note when I got the car initially running, I took the pump apart, cleaned it, and even bench tested and ran it. I have no idea what happened to the 3 port, during the year of sitting, but I cut my losses and switched to a new 2 port, re plumed, and now it runs again. I recently picked up a recently used 3 port from a member. Did a quick test to verify it worked before putting it on the shelf and it was stuck. A few minutes of switching leads got it free. Evidently our wonderful ethanol blended gas gummed up the works as part of it evaporated. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:43 AM |
