Only slightly OT: spray carpet die can be really handy |
Tdskip |
Dec 8 2019, 02:18 PM
I have to admit I was very skeptical before having actually tried this, but I have to say it’s exceeded my expectations.
This is the 1984 928 that sat badly stored outside in Tustin for 18 years before I rescued it. It only had 74,000 miles on it, so the materials were not worn out they were just a bit dirty and sun faded. After cleaning the carpet surfaces really well but gently and allowing it to dry I brushed it with a stiff nylon brush. After that I sprayed a very light coat of die and then immediately worked it in with the same brush. I expect there may be disagreement on this but for my daily driver use this is perfectly acceptable. Well worth the $16 can and some elbow grease. |
aj88cab |
Dec 9 2019, 11:13 AM
Newbie Group: Members Posts: 1 Joined: 20-July 06 From: Marietta, GA (Atlanta) Member No.: 6,471 |
I have used liquid Rit Fabric die, with good results. Used a pump spray bottle for in car carpet applications. Mixed about 4 parts water to 1 part dye (that stuff is concentrated!). I use a brush to work it in and/or massage it in with nitrile gloves in those hard to reach spots. Takes a day in the hot sun to dry completely, but for a cheap SOB like me, it beats a $20 rattle can. As noted, a clean carpet is key for good & lasting results.
I have also used it in a big plastic tub for recoloring original factory floor mats, if they are not all worn out. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:22 PM |
