Ignition switch/seatbelt interlock problem? '74 2.0, Another newby question |
Robson51 |
Dec 8 2019, 04:31 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Well, my son and I need to learn to communicate better....when he told me the car "wouldn't start" after we did fuel lines, etc, my thought was it was probably fuel related. Turns out what he meant was when you turn the key-nothing.....starter does not engage. Crawled under the car and jumped it, and with a bit of ether it started right up and settled down nicely after a couple minutes.
So in searching, I see that there are lots of posts about bad ignition switches, and I found one wiring diagram that indicated a "seat belt interlock". Somehow, something has happened over the last couple weeks, and some interior disassembly, to have the ignition switch not activate the starter. Is there an interlock that would interfere with starting the car? How do I jump around it? Or is this all symptomatic of a sudden unexplainable failure of the ignition switch? Any sources for a good wiring diagram for a '74 2.0? Thanks in advance- Rob |
sixnotfour |
Dec 8 2019, 05:11 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
http://www.914world.com/bbs2/index.php?showtopic=246814#
after doing this , no start prob. ignitition switch....or simple voltage check at the terminals ..when turning key to start.. Attached image(s) |
Robson51 |
Dec 8 2019, 06:10 PM
[quote name='sixnotfour' date='Dec 8 2019, 03:11 PM' post='2768352']
http://www.914world.com/bbs2/index.php?showtopic=246814# after doing this , no start prob. ignitition switch....or simple voltage check at the terminals ..when turning key to start.. [/ Still learning my way around this car. Where is all this located? Thanks |
Robson51 |
Dec 8 2019, 06:12 PM
http://www.914world.com/bbs2/index.php?showtopic=246814# after doing this , no start prob. ignitition switch....or simple voltage check at the terminals ..when turning key to start.. Sorry! Wasn’t smart enough to click on the link! |
type2man |
Dec 8 2019, 06:19 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
On my car, the plastic part of the ignition switch had cracked and the key would not turn the plastic part enough to engage the starter.
Robson51 |
Dec 8 2019, 07:13 PM
http://www.914world.com/bbs2/index.php?showtopic=246814# after doing this , no start prob. ignitition switch....or simple voltage check at the terminals ..when turning key to start.. That fixed it! Thanks! |
Lo-Fi Version | Time is now: 29th April 2024 - 11:02 AM |
