Name these wheels and will they fit? |
DucRS |
Dec 10 2019, 06:00 PM
Member Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California |
john77 |
Dec 10 2019, 06:32 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
They look like Enkeis 92’s.
Looking at the width between bead seats they look like 6’s, so I think they should fit. I’m running 16 x 7s all round which is just too much, my rear arches had to be pulled for them to fit. The fronts rub the rear of wheel well on full lock too (that’s with max camber) but it’s not that big a deal. |
DickSteinkamp |
Dec 10 2019, 06:39 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Those look like they are 5 1/2"...maybe 6" wide (measure inside rim lip to inside rim lip)
Is the bolt circle 130mm? What size tires do you plan to run? |
DucRS |
Dec 10 2019, 07:22 PM
Those look like they are 5 1/2"...maybe 6" wide (measure inside rim lip to inside rim lip) Is the bolt circle 130mm? What size tires do you plan to run? Found these on a local Classified add for $400 OBO and thought these might make a cool alternative to the stock Fuchs currently on. What do you guys think, yay or nay? The guy selling is cleaning out his dads 914 leftovers so I’m assuming it’s a straight fit. When it comes to tires I haven’t the slightest idea at the moment, any suggestions? |
DickSteinkamp |
Dec 10 2019, 07:37 PM
Any 16" tire of the same diameter as the stock 165 80 15 would need a much wider wheel...but that may not be one of your goals.
Unless those wheels are much more special than I can imagine, or if they are THE wheels you've been lusting after, I don't think they are worth the asking price. |
bkrantz |
Dec 10 2019, 09:31 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Agree they look like Enkei 15 x 5.5.
Are they hub-centric? |
johnhora |
Dec 10 2019, 10:19 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
DucRS...
If your 914 is stock and looks like the nice yellow 914 picture in your avatar. Forget these wheels and keep your Fuchs...The Fuchs are much better wheels.. Use the money some place else on the car. |
Big Len |
Dec 10 2019, 11:00 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
DucRS... If your 914 is stock and looks like the nice yellow 914 picture in your avatar. Forget these wheels and keep your Fuchs...The Fuchs are much better wheels.. Use the money some place else on the car. Couldn't disagree more. They would look great on your car. It's just a wheel, easily changeable, do what you want. |
twistedstang |
Dec 11 2019, 02:52 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
Black mesh wheels look great on anything !
tomh |
Dec 11 2019, 03:33 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
dr914@autoatlanta.com |
Dec 11 2019, 03:38 PM
914 Guru Group: Members Posts: 7,853 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes they are enkeis, used to sell many, have the vw offset though so cannot fit the widest tire.
DucRS |
Dec 11 2019, 04:14 PM
Yes, this is my bone stock 73 914 2.0 in avatar. I was just thinking about a second set of wheels for those days when I’m feeling a lil outlawish (IMG:style_emoticons/default/ar15.gif) than stock. Apparently the Enkei wheels don’t quite do it. The search continues
ndfrigi |
Dec 11 2019, 04:26 PM
I think same with the wheels of one of the former car of Ric 918-S.
DucRS |
Dec 11 2019, 04:55 PM
Yup, these look spot on and looks pretty nice (IMG:style_emoticons/default/idea.gif)
sixnotfour |
Dec 11 2019, 08:00 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE Apparently the Enkei wheels don’t quite do it. if you like em ..do it.. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:59 PM |
