New Heads unpacking, Camper Specials from Type4Store |
malcolm2 |
Dec 10 2019, 09:27 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I figured this group might enjoy seeing my Christmas present to myself. These are for my 72 VW bus. They cost more THAN my bus. LOL.....I did not opt for the Ceramic coating. But as stated these are Camper Specials, New 1.8 AMC castings, Type4store's 2 liter sized SS valves, springs, keepers, etc... modified ports, proprietary valve seats that you can see are inserted deeper, plus a notch for an under plug CHT thermocouple.
Still to come is a Type4store 9590 cam kit with cut to fit Chromoly push rods, solid lifters, swivel foot adjusters, I forget what else. Merry Christmas to me. (IMG:style_emoticons/default/piratenanner.gif) |
914Sixer |
Dec 10 2019, 10:06 PM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sweet present (IMG:style_emoticons/default/santa_smiley.gif)
Mark Henry |
Dec 10 2019, 10:17 PM
maf914 |
Dec 11 2019, 06:53 AM
Nice! Those should be good to go.
Is this the notch for the CHT thermocouple? Could someone comment on what sort of tool was used to make the cut? Attached image(s) |
peteyd |
Dec 11 2019, 07:15 AM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
TargaToy |
Dec 11 2019, 09:47 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Wow...those are pretty!
Is this the outcome to the discussion the other week on whether or not anyone still rebuilds 1.8 heads? (IMG:style_emoticons/default/biggrin.gif) |
Bleyseng |
Dec 11 2019, 09:57 AM
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too.
malcolm2 |
Dec 11 2019, 09:58 AM
Wow...those are pretty! Is this the outcome to the discussion the other week on whether or not anyone still rebuilds 1.8 heads? (IMG:style_emoticons/default/biggrin.gif) It is certainly my outcome. I would have liked to have been able to have had the 1.8 heads for this engine rebuilt. But I could not find anyone that I would trust to do it locally. Shipping heavy stuff is expensive. I called a Head place here in Nashville and got the sales pitch of the day. And how "straight-forward" type 4 vw heads are. No details on seats, or porting, etc... That is when I knew that he did not know specifically about type 4 heads. Oh he was gonna be cheap, but that was not my goal. Len rebuilt my 914's 1.8 heads back in 2012. I guess NEW is the way to go, now. Between him, Jake and the type4Store, they say that no one has called and let them know that a seat has dropped on any heads like this that they have sold. My fingers are crossed. (IMG:style_emoticons/default/piratenanner.gif) http://aircooledtechnology.com/cylinder-heads/ I investigated getting AMC heads from AA, but all their valves and ports are 1.7 sized. They claim that the heads is a 2.0, but the valves are too small. Their new AMC heads are about 1/3 as expensive, but I believe they are 100% AMC. |
malcolm2 |
Dec 11 2019, 10:03 AM
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too. What pistons and crank do you have in your bus? I am considering getting new rings and putting the 93mm pistons back in with the stock 66mm crank. I bought some rings but the bottom ring assembly was 4mm thick. too big for the 3mm trough. Sent them back and suggested that they stop selling them as suitable for 93mm type 4 pistons. |
barefoot |
Dec 11 2019, 10:10 AM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I figured this group might enjoy seeing my Christmas present to myself. These are for my 72 VW bus. They cost more THAN my bus. LOL.....I did not opt for the Ceramic coating. But as stated these are Camper Specials, New 1.8 AMC castings, Type4store's 2 liter sized SS valves, springs, keepers, etc... modified ports, proprietary valve seats that you can see are inserted deeper, plus a notch for an under plug CHT thermocouple. Still to come is a Type4store 9590 cam kit with cut to fit Chromoly push rods, solid lifters, swivel foot adjusters, I forget what else. Merry Christmas to me. (IMG:style_emoticons/default/piratenanner.gif) These are the small 48cc chambers vs the 2L heads 60cc chambers, nice for higher compression !! |
malcolm2 |
Dec 11 2019, 10:45 AM
These are the small 48cc chambers vs the 2L heads 60cc chambers, nice for higher compression !! Yes. specs from vendor Castings: AMC Chambers: 48.5-49.5cc’s, Stock 2.0 Bus Chamber Step: .75mm to simulate O.E. head gasket thickness.* Plug angle: Stock 2.0 Bus Valve sizes: 42 x 36 Intake Ports: Stock AMC with hand blending to seats. Exhaust Ports: Long side radius machined with in-house designed cutter, short side radius chamfered. I am going VW Bus stock. 7.3-ish CR, IIRC. my 914 has similar heads but the rebuilt casting.... with 2.0 sized valves. |
Bleyseng |
Dec 11 2019, 01:03 PM
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too. What pistons and crank do you have in your bus? I am considering getting new rings and putting the 93mm pistons back in with the stock 66mm crank. I bought some rings but the bottom ring assembly was 4mm thick. too big for the 3mm trough. Sent them back and suggested that they stop selling them as suitable for 93mm type 4 pistons. I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! |
malcolm2 |
Dec 11 2019, 01:44 PM
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! 3 choices for me.... buy 93mm rings ($50) 1756 cc or 96mm P/C ($400 non-nickies) 1911 cc or 71mm crank, 96mm p/c ($700) 2056 cc EDIT: and 2.0 rods ($300 more) Further edit: I guess I could go full 2.0 and just use 94.5mm P/C 1985 cc? I am in this deep, maybe I should go 2056? |
Mikey914 |
Dec 11 2019, 04:40 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The math works, not stupid money and you are doing the work anyhow so.............
Al Meredith |
Dec 11 2019, 05:19 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have a 1911 (96X66) with Len Hoffman heads and all of type 4 store set up and a 2056 (96X71) with Len Hoffman heads and all of Type 4 store stuff . Both with carbs . The 2056 is the way to go because of the torque. I have been to Lens shop many times and I can tell you he is very meticulous, weighs and measures everything and has the coolest equipment. Like Jake if he tells you something it's the right way to go.
Bleyseng |
Dec 11 2019, 06:14 PM
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! 3 choices for me.... buy 93mm rings ($50) 1756 cc or 96mm P/C ($400 non-nickies) 1911 cc or 71mm crank, 96mm p/c ($700) 2056 cc I am in this deep, maybe I should go 2056? If you are going to the trouble of rebuilding the engine it just makes sense to go to a 2056 as its such a better engine. More hp and torque for alittle more money |
jcd914 |
Dec 11 2019, 07:36 PM
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! 3 choices for me.... buy 93mm rings ($50) 1756 cc or 96mm P/C ($400 non-nickies) 1911 cc or 71mm crank, 96mm p/c ($700) 2056 cc I am in this deep, maybe I should go 2056? You need to include 2.0L rods with the 71mm crank and 96mm P&Cs to get your 2056. Your 1.7 rods won't work with teh 2.0 crank. 2056 would be my choice. Jim |
Bleyseng |
Dec 11 2019, 07:58 PM
Super common as type4 buses used the same 2.0L ones
Mark Henry |
Dec 12 2019, 04:33 AM
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! (IMG:style_emoticons/default/agree.gif) This is exactly what I'd run in a bus, I wouldn't use the 96mm, you need the thicker wall cylinders. No replacement for displacement, that's what the 71mm crank and rods give you, but you also need the parts to be robust for high loads you can pack into a bus. Put a full skid of flooring into your bus, plus a trailer with just as much weight and then start pulling some good grades, your engine will be much happier with the 94's. Back in the 90's I would vacation in Florida plus make 2-3 trips to the US on summer holidays, everytime I would take my 12' car trailer and always come back with a bug on the back plus a load of car parts. My bus ran like a champ everytime. (IMG:http://www.914world.com/bbs2/uploads/post-26-1222565915.jpg) |
SteveL |
Dec 12 2019, 07:44 AM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Mark - you pulled a trailer with a BUS? You gotta be BSing us, right? How much HP and torque in that bus?
Lo-Fi Version | Time is now: 10th May 2024 - 03:26 PM |
