Fuel Cell, Need a recommendation |
Charles Freeborn |
Dec 12 2019, 03:37 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
What are y'all running for a fuel cell. Required by SVRA:
M: Fuel Cells Fuel Cells: All cars, other than pre-war, must have a Fuel Cell that meets FIA FT-3 specification or equivalent SFI 28.3 specification. The Fuel Cell “Bladder” must be maintained according to the manufactures recommendations. There must be a solid bulkhead (fire wall) completely separating the fuel tank, fuel pump, fuel cell, filler neck hoses, and/or vent lines, from the drivers compartment. Vent lines must exit the trunk/bodywork area. |
vintage914racer |
Dec 13 2019, 06:39 PM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
I'm running a ATL 12 gallon in my -6. I'll track down a photo and post shortly
wndsrfr |
Dec 14 2019, 10:04 AM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Mine's a fuel safe 15 gal with the internal pickup box that traps fuel through little trap doors.
Note the screen type in line filter on the pickup line. Highly recommend it. There was enough debris on it to starve the engine by my second tank of fuel. Looked like bits of plastic so not happy with Fuel Safe. I clean it out every race day and still get a bit after two years so look into the ATL first, just sayin. Attached thumbnail(s) |
brant |
Dec 16 2019, 11:58 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mine's a fuel safe 15 gal with the internal pickup box that traps fuel through little trap doors. Note the screen type in line filter on the pickup line. Highly recommend it. There was enough debris on it to starve the engine by my second tank of fuel. Looked like bits of plastic so not happy with Fuel Safe. I clean it out every race day and still get a bit after two years so look into the ATL first, just sayin. John, about the contaminate are you finding in the filter that is so weird.... is it small pieces of the fuel cell foam? (same color as the foam perhaps) I know they disintegrate after a few years and replacing the cell foam (crazy expensive) is a maintenance item now and then. I pull my fuel filter 1x a year and it is almost always absolutely clean I have found a blade of grass in it once, and other small items. but 2 out of 3 years it is spotless. weird. brant |
wndsrfr |
Dec 17 2019, 07:24 AM
Mine's a fuel safe 15 gal with the internal pickup box that traps fuel through little trap doors. Note the screen type in line filter on the pickup line. Highly recommend it. There was enough debris on it to starve the engine by my second tank of fuel. Looked like bits of plastic so not happy with Fuel Safe. I clean it out every race day and still get a bit after two years so look into the ATL first, just sayin. John, about the contaminate are you finding in the filter that is so weird.... is it small pieces of the fuel cell foam? (same color as the foam perhaps) I know they disintegrate after a few years and replacing the cell foam (crazy expensive) is a maintenance item now and then. I pull my fuel filter 1x a year and it is almost always absolutely clean I have found a blade of grass in it once, and other small items. but 2 out of 3 years it is spotless. weird. brant Some black specks, some foam bits... still get a bit on the screen about every 2 hours on track. Now it's just a 5 minute part of the fueling drill just take it apart squirt a shot of brake keen in reverse direction & blow it out. Not happy though. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:10 PM |
