> 914World Classifieds Rules
3 Pages V  1 2 3 >
> FS: Billet Tuna Can - NEW!, * Featured Item *
914werke
post Dec 14 2019, 07:38 PM
Here is a solution for oil starvation when driving your 914/4 in the manner it was designed!!
Highly recommended for ANY 914, street or tracked.
Simple install.
Available HERE & in the members vendor section
CHIZ 914
post Dec 16 2019, 11:14 AM
Put me down for one
Thanks Rich!
914werke
post Feb 14 2020, 10:59 AM
second wind
post Apr 2 2020, 09:37 PM
Hello there.....is it wrong thinking on my part that this will somehow get hit since it is lower that the stock set-up? I like the idea of more oil and curing the starvation of oil issue which I know nothing about. Please share a little more of why this is a good idea. Thank you very much.
gg
914werke
post Apr 2 2020, 10:39 PM
Its a common concern but in reality the sump once installed is no lower than the engine mount bar. If you are dragging the sump on anything, there is something else going on ~
Its purpose it to MAINTAIN oil pressure.
The 914 was designed to be capable of navigating curvy roads at high rates of speed and (with the right tires) + G-force's.
The result of which is to cause the oil in the bottom of the engine to slosh away from the pickup. By extending the PU into a small oil reservoir at the lowest point of the engine, that should never occur.
pete-stevers
post Jun 25 2020, 08:09 PM
saved from fire!
Group: Validating
Hey Rich I need to put an order together for you!
drem914
post Jun 25 2020, 09:33 PM
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required?
914werke
post Jun 25 2020, 10:33 PM
QUOTE(pete-stevers @ Jun 25 2020, 07:09 PM) *
You got my # (IMG:style_emoticons/default/smile.gif)
914werke
post Jun 25 2020, 10:41 PM
QUOTE(drem914 @ Jun 25 2020, 08:33 PM) *
Typically the stock sump cover isnt an area I see a lot of leaking. (IMG:style_emoticons/default/confused24.gif)
Unless of course your sump mount boss had been over torqued & isnt holding?
The cap nut seal is the only other area I can see leaking, it is replaced with an
tapered female bolt.
No extra gaskets or special prep is necessary unless you plan on running it with the screen. (IMG:style_emoticons/default/smile.gif)
drem914
post Jun 26 2020, 09:47 PM
Just put in an order. I think you had sump extension instructions posted somewhere?
914werke
post Jun 27 2020, 12:25 AM
QUOTE(drem914 @ Jun 26 2020, 08:47 PM) *
You will receive a copy with the order but I also have it posted on the downloads section
on 914werke.com (IMG:style_emoticons/default/smile.gif)
Tdskip
post Aug 11 2020, 01:42 PM
@914werke - Rich, are these steel or aluminum? When you go to order it shows a "Raw" as to the finish but the pictures show metal or black finish.
914werke
post Aug 11 2020, 02:32 PM
QUOTE(Tdskip @ Aug 11 2020, 12:42 PM) *
They are anodized aluminum. (IMG:style_emoticons/default/smile.gif)
Initially I offered both black & raw (or Alum.) finish.. but no one wanted the black so I made that a special order option.
RolinkHaus
post Oct 14 2020, 05:11 AM
I will take one too, paypal ok
914werke
post Oct 14 2020, 11:17 AM
QUOTE(RolinkHaus @ Oct 14 2020, 04:11 AM) *
PM sent
drem914
post Apr 10 2021, 01:55 PM
QUOTE(914werke @ Jun 25 2020, 09:41 PM) *
@914werke Getting ready to install but had a couple questions:
1. Is there any added benefit to running the screen with the extend sump?
2. If the screen is used can I use an RTV to connect or should it be tack welded or soldered instead?
914werke
post Apr 10 2021, 03:29 PM
Given that the screen will only stop rather large pieces of debris, the reality is at that point you recognize its catching stuff,
you have bigger problems to be concerned with. (IMG:style_emoticons/default/sad.gif)
My belief is the screen is a hold over from the T1 design w/o a spin on filter.
So no its not necessary.
But.. if you want you use it, its not that hard.
1st - you need a third sealing ring to sandwich the screen flange between the sump mating surface & the cover.
2nd - you need to ream the hole in the thin alum. on the bottom of the screen that is only as large as the M6(?) sump stud, to a hole that will fit the female securing stud .. snugly. Go slow & work up to your fit. If you just hit it with a drill bit you may not like the results BTDT.
Last - I also used a file & opened up the slots on the base to allow a bit more flow, no real evidence that it is necessary it just made me feel better.
drem914
post Apr 11 2021, 11:56 AM
Thanks. What "sealant" should be used, as noted in your printed instructions, to connect the extender collar?
FlacaProductions
post Apr 11 2021, 12:12 PM
Permatex Motoseal 1 or Honda/Yamabond - same stuff, I believe.
Remember - the oil sump plate is 9 ft/lbs which is 108 inch/lbs...not a pound more.
This may help:
http://www.914world.com/bbs2/index.php?act...t&id=716717
or this - long thread but this will get you in there:
http://www.914world.com/bbs2/index.php?sho...tuna&st=100
If you search "tuna" it should yield a lot of threads.
914werke
post May 17 2021, 08:44 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 30th June 2025 - 07:50 PM
