FS: Billet Tuna Can - NEW!, * Featured Item * |
914werke |
Dec 14 2019, 07:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Here is a solution for oil starvation when driving your 914/4 in the manner it was designed!!
Highly recommended for ANY 914, street or tracked. Simple install. Available HERE & in the members vendor section (IMG:style_emoticons/default/bye1.gif) |
914werke |
Jun 25 2020, 10:41 PM
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required? Typically the stock sump cover isnt an area I see a lot of leaking. (IMG:style_emoticons/default/confused24.gif) Unless of course your sump mount boss had been over torqued & isnt holding? The cap nut seal is the only other area I can see leaking, it is replaced with an tapered female bolt. No extra gaskets or special prep is necessary unless you plan on running it with the screen. (IMG:style_emoticons/default/smile.gif) |
drem914 |
Apr 10 2021, 01:55 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required? Typically the stock sump cover isnt an area I see a lot of leaking. (IMG:style_emoticons/default/confused24.gif) Unless of course your sump mount boss had been over torqued & isnt holding? The cap nut seal is the only other area I can see leaking, it is replaced with an tapered female bolt. No extra gaskets or special prep is necessary unless you plan on running it with the screen. (IMG:style_emoticons/default/smile.gif) @914werke Getting ready to install but had a couple questions: 1. Is there any added benefit to running the screen with the extend sump? 2. If the screen is used can I use an RTV to connect or should it be tack welded or soldered instead? |
Lo-Fi Version | Time is now: 9th May 2024 - 12:35 PM |
