fused and relayed front electricals |
90quattrocoupe |
Dec 15 2019, 11:54 AM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
So my car is up at PMB performance for a little work. I am not much of an electrical type person, when it comes to cars. So I asked them to install fuses and relays for the headlights, fogs and horns. You know, switches getting a little old and don't want to put undo stress on them.
This is a picture of where they installed them. I think they did a nice job. The fuse box is a BLUE SEA SYSTEMS–ST Blade Compact 4-Circuit Fuse Block The relay box is a HELLA H84988001 4-Way Mini Relay Box Kit Greg W. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20561-1576432754.1.jpg) |
windforfun |
Dec 15 2019, 05:26 PM
Senior Member Group: Members Posts: 1,792 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
IMHO & if you have a choice, fuses are best placed before all the wiring that provides the power. The basic fuse panel under the dash or close to the battery is actually the safest way to go. Fuses at the battery are the best.
90quattrocoupe |
Dec 16 2019, 01:24 PM
IMHO & if you have a choice, fuses are best placed before all the wiring that provides the power. The basic fuse panel under the dash or close to the battery is actually the safest way to go. Fuses at the battery are the best. Unless I am mistaken, the fuses do come in before providing power. The hot lead is at the bottom of the fuse box, through fuses with, leads providing power to the relays. The switches at the dash are just switching the relays on and off. Greg W. |
lierofox |
Dec 16 2019, 06:32 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Unless I am mistaken, the fuses do come in before providing power. The hot lead is at the bottom of the fuse box, through fuses with, leads providing power to the relays. The switches at the dash are just switching the relays on and off. Greg W. There's a set of wires that are un-fused for a considerable distance, one set goes to the engine bay relay board, one going to the under-dash fuse panel to fuses 10, 11 and 12, and one going to the ignition switch. So if any of those wires chafe and short to ground, there's no protection of any kind. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:16 PM |
