Ugly Duckling to a Blue Bird, Roller into a 6 Conversion |
Sway Bar |
Oct 19 2020, 01:32 PM
Member Group: Members Posts: 88 Joined: 17-December 19 From: Okanagan Valley, Great White North Member No.: 23,743 Region Association: None |
So the first start up was the other day and of course I couldn't leave good enough alone. I have no idea what muffler I have. Its not a Dansk to me since it's way too light and it has no other markings (Bicshoff or Leistritz??). Anyway, it's good but I miss a little snarl. I love the very early M&K I have on my 911 but this is what I have on hand so....
In the nature of reuse and recycle I used left over shock covers and then made some caps from some left over materials. Some through pins finished the look and functionality. |
mb911 |
Oct 19 2020, 04:58 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Very nice.. I like the clips you used.. A good idea. How old of an m&k do you have ? Just wondering if it was one of mine when I owned the company
Gint |
Oct 19 2020, 07:10 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
IT STARTS!!...so after 8 years of sitting in a box I finally tried to start this motor. Of course I had my troubles. I had a small leak from a fitting at the front tank (arrgghh) and couldn't get proper ignition until I move the distributor over a tooth (thank goodness for the access panel) Still a lot of tuning to do. That's great! (IMG:style_emoticons/default/smilie_pokal.gif) |
Sway Bar |
Oct 19 2020, 07:43 PM
Very nice.. I like the clips you used.. A good idea. How old of an m&k do you have ? Just wondering if it was one of mine when I owned the company It could be?....I got it used already about 10 years ago. Its awesome! Just loud enough but still civil but really wakes up above 4K. It went from my 2.4LMFI to my 3.0L MFI. To this day I get compliments on the sound regardless of what other Pcars are around. |
mb911 |
Oct 19 2020, 07:46 PM
Yup one of my Gen 2s remember making those in my garage at 2 in the morning.. Glad to see its still around.
Sway Bar |
Oct 19 2020, 07:56 PM
So speaking of sound.... here is my home grown rally exhaust.
Carbs still need to be tuned. Running super rich I think one bank and lean on one intake. Still burning off oil that I squirted into each cylinder 8 years ago plus who knows what was left in that muffler (at least no mice nests). The missus wasn't so happy when she opened the garage door (IMG:style_emoticons/default/sad.gif) After about 20min things cleared up nice. So, here is normal mode... https://www.youtube.com/watch?v=WJRX_0RwJlY Now with the single capped off (I think real rally mode should have all open?)...to me it sounds like I gained a liter of displacement (IMG:style_emoticons/default/aktion035.gif) Phone Mics don't do it justice. https://www.youtube.com/watch?v=XNCBnO7QsQ8 |
Sway Bar |
Oct 22 2020, 03:40 PM
Well progress halted for a bit. When I got the 'bag' of undercarriage parts that started this whole process it had 911 axles, cv's, and cv adapters. I even had an additional set of 911 axels/cv's. I was all set...wrong!!
I never really looked too closely and measured anything. I did know that the 914 trans output shafts were too small so I managed to source some coarse spline 911 ones. So, got ready to put everything together and the adapter doesn't fit?? 9mm too small in diameter. I guess whoever started this had, I believe the 2 year only, 915 100mm output flanges. (IMG:style_emoticons/default/headbang.gif) At this point forget trying for a work around or other adapters and I just did it the quick and simple way (so more money). Now I'm really ready for bigger horse power. (IMG:style_emoticons/default/biggrin.gif) (I still need some half moons- 2 sets of axles but only a half set of washers??) Finished the shift head and hoped for a fairly decent shift pattern. |
Sway Bar |
Oct 23 2020, 10:05 AM
IT MOVES! (IMG:style_emoticons/default/piratenanner.gif)
So after who knows how many years (it was a roller after all) I of course wanted to see if it will move and if I remember that shifter feeling from 25 years ago....yup, like I remembered; a wooden spoon in a pot of porridge (IMG:style_emoticons/default/biggrin.gif) I did a quick run around the neighborhood since it's not licensed. I have to get it inspected next spring in order to do so. My timing is off but now I have all winter to figure out the last items: -hand brake cable (the little interior one)- source, install and test -Driver Door mirror (source and install) -CV half moons (source and install) -Test Wiper fluid reservoir and pump (test) -figure out oil temp and oil pressure gauge (I have 911 gauge but so far no signal) -Finish wheels and need new rubber -install front belly pan cover -Maybe find and install some euro tail lenses...I think they would look good against the blue I think that's it. Would love to do some more driving but I now have this coming down So for those that have to hibernate for this early winter stay safe and warm and for those of you that live in more hospitable winter environments, get out there and work on your projects or those that are done, get out driving. (IMG:style_emoticons/default/aktion035.gif) Cheers |
Lo-Fi Version | Time is now: 4th May 2024 - 09:44 PM |
