Where do people put the DME on a 3.2 L 914/6 conversion |
Tdskip |
Dec 19 2019, 08:22 PM
Is there a best practice I should be aware of here as I continue to plan this out?
Thanks! |
Mark Henry |
Dec 19 2019, 08:31 PM
mepstein |
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Behind the driver or passenger seat most often.
Once I clean up some wires, I want to see if I can get it to the passenger footwell. If I can't, It may go between the seats in a little custom cover. It should always be kept dry and cool. |
Tdskip |
Dec 19 2019, 08:54 PM
Ha, so extra long extension cord or someone running with it next to the car is not an option. Got it. @mepstein - are you planning on modifying the interior backpad or, instead, passing it through and mounting it on the interior side of the backpad? Sounds like that later. Thanks! |
ClayPerrine |
Dec 19 2019, 09:04 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I put mine under the foam block on the passenger footwell. But I had to extend the DME harness to make it reach.
If I were going to do it again, I would put it in the middle of the car under the back pad. |
Tdskip |
Dec 19 2019, 09:06 PM
SirAndy |
Dec 19 2019, 09:10 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Under the dash on the passenger side ...
(IMG:style_emoticons/default/popcorn[1].gif) |
mepstein |
Dec 19 2019, 09:14 PM
I don’t think mine will reach but that would be the perfect spot. |
ClayPerrine |
Where? I couldn't find a spot under there. Do you have a picture? |
Tdskip |
Dec 19 2019, 09:18 PM
Don’t think mine will reach either, great spot however
mepstein |
Dec 19 2019, 09:19 PM
Ha, so extra long extension cord or someone running with it next to the car is not an option. Got it. @mepstein - are you planning on modifying the interior backpad or, instead, passing it through and mounting it on the interior side of the backpad? Sounds like that later. Thanks! I went through the “dimple” on the lower part of the firewall, behind the right seat. I did cut short the stock early backpad by about 2 inches on that side. Doesn’t show behind the seat since I left the viny and it covers the wire bundle. Eventually I will replace with a later adjustable seat and perlon. |
SirAndy |
Dec 19 2019, 10:47 PM
Where? I couldn't find a spot under there. Do you have a picture? http://www.914world.com/bbs2/index.php?s=&...st&p=883879 The PMS harness was actually long enough to mount the brain horizontally under the dash in the position where Mark is holding it vertically in the picture. We mounted it on a custom frame using rubber isolators to counteract vibrations. It's tucked away so nicely that you can't see it at all unless you get your head under the dash ... (IMG:style_emoticons/default/smile.gif) |
SirAndy |
Dec 19 2019, 10:49 PM
The PMS harness was actually long enough to mount the brain horizontally under the dash in the position where Mark is holding it vertically in the picture. We mounted it on a custom frame using rubber isolators to counteract vibrations. It's tucked away so nicely that you can't see it at all unless you get your head under the dash ... (IMG:style_emoticons/default/smile.gif) @ClayPerrine @mepstein http://www.914world.com/bbs2/index.php?s=&...st&p=893545 (IMG:http://www.914world.com/bbs2/uploads/post-179-1177645321.jpg) |
Steve |
Dec 19 2019, 11:23 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Mine fits perfect behind the drivers seat. I use a longer backpad screw to hold it in place. The DME relay and altitude sensor is behind the passenger seat. Did not have to modify any of the cables.
sixnotfour |
Dec 19 2019, 11:36 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Don’t think mine will reach either, great spot however (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) just another..what if thread.....rear trunk ..under seat, under glove box.. Surprise Us .... |
Tdskip |
Dec 20 2019, 09:13 AM
Don’t think mine will reach either, great spot however (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) just another..what if thread.....rear trunk ..under seat, under glove box.. Surprise Us .... @Steve - I noticed you don't have a sound pad in the engine compartment, how is the noise level for longer trips? @sixnotfour - nope, not a "what if" thread, a making sure when I do it early next year I get it right having learned from the people here thread. Tell you what - want to bet $1,000 it gets done? |
Maltese Falcon |
Dec 20 2019, 11:04 AM
Advanced Member Group: Members Posts: 4,658 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I've seen a few conversions where the DME/ alt-comp + dme relay were cleanly mounted in the rear trunk. Still able to store the targa top. I like the accessibility of getting to the relay, it can be popped out on occassion...adds another level of anti-theft (IMG:style_emoticons/default/smile.gif)
sixnotfour |
Dec 20 2019, 12:05 PM
http://www.914world.com/bbs2/index.php?showtopic=116617
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/santa_smiley.gif) Attached image(s) |
sixnotfour |
Dec 20 2019, 12:28 PM
Attached image(s) |
Cairo94507 |
Dec 20 2019, 02:19 PM
Michael Group: Members Posts: 9,772 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Mine is under the driver's seat. Definitely wanted it in the interior of the car.
Lo-Fi Version | Time is now: 20th May 2024 - 03:39 PM |
