porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,920 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Any where Porsche don't put them,what were they thinking with the footwell and floor locations (IMG:style_emoticons/default/WTF.gif) ,hell even the one in my 944 got drowned,Motronic ECU's are hardly cheap to replace and many now are getting old and failing without being wet.
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,740 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Thanks for the ideas and pictures. I’d be inclined to think that interior of the car but off the floor would be the safest place.
Quick shout out to @MB911 for spending some time with me today on parts planning. |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,057 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Any where Porsche don't put them,what were they thinking with the footwell and floor locations (IMG:style_emoticons/default/WTF.gif) ,hell even the one in my 944 got drowned,Motronic ECU's are hardly cheap to replace and many now are getting old and failing without being wet. Some of them used a circuit board that wasn’t much more than compressed paper. Porsche still places a lot of electronics down low. |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,107 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
A friend had his 996 cab (top up) windows down, parked in his garage / laundry area. While he was on holiday, a water hose entering the wash machine burst and doused the car for a weekend. Most of the water made it out the garage floor drain...except for the interior floor of the 996. Fully insured and $$$ claim fixed the moldy carpets & cables / ecu/ relays
SKI-HI |
Newbie ![]() Group: Members Posts: 8 Joined: 21-July 17 From: Alberta Member No.: 21,274 Region Association: Canada ![]() |
Mine is in the rear trunk. Stock harness ,works great .
Tdskip |
Boxster ECU issues due to wet floors are not uncommon from wha I’ve read.
Going on the inside somewhere, likely mounted vertically. I did order a PMS harness today so will see it is reaches up front, will report back. Thanks all! |
The PMS harness connects the chassis harness to the engine harness. It doesn't connect the ECU to the car. It won't lengthen the DME harness.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,927 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Don’t think mine will reach either, great spot however (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) just another..what if thread.....rear trunk ..under seat, under glove box.. Surprise Us .... @Steve - I noticed you don't have a sound pad in the engine compartment, how is the noise level for longer trips? @sixnotfour - nope, not a "what if" thread, a making sure when I do it early next year I get it right having learned from the people here thread. Tell you what - want to bet $1,000 it gets done? I have an amplifier in the front trunk, so I just crank the stereo louder than the motor if I do not want to listen to the motor. It is on my list to install 914rubber's engine compartment firewall pad and see how much it helps. Otherwise the motor is loud. Much louder than my 2.7 with webers, but I had a stock sound pad with that motor. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,311 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The PMS harness connects the chassis harness to the engine harness. It doesn't connect the ECU to the car. It won't lengthen the DME harness. My harness to the DME appears to be longer than normal and came from PMS ... (IMG:style_emoticons/default/shades.gif) |
buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 554 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
Mine is placed in the center console vertically.
Tdskip |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you made a watershield, like a small aluminum box why not put it in the engine bay?
I had my SDS EFI system in a hollowed out D-jet box in the stock location, now my MSD box is in the same place now with just a water shield over the top. If it needs a bigger box there's lots of room on the firewall just behind the drivers seat. the box would need to be waterproof up top but the bottom doesn't need to be. I'd wire it through the bottom and would add drain holes to the bottom even if I semi-sealed it. |
The PMS harness connects the chassis harness to the engine harness. It doesn't connect the ECU to the car. It won't lengthen the DME harness. Oops! Thanks for the clarification. It’s still a product worth buying. It makes wiring the engine to the chassis a two minute job. I wish there was a similar adaptor from the DME to the car. |
scallyk9 |
Member ![]() ![]() Group: Members Posts: 360 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest ![]() ![]() |
My DME for the 3.2L is located vertically just off the floor, in front of the stock backpad and behind the passenger seat. Relay is next to it with a spare in the glovebox. The seat still retracts but not quite fully flush into the backpad. Works well and no moisture access.
Tdskip |
@mepstein - true, yes, but a bit embarrassing I got my parts confused .
Anymore pictures of how you guys mounted them on the inside to the backpad? Did you weld some mounting screws on the firewall and then have them poke through the backpad? Thanks ( and happy Saturday to everyone ) |
Coondog |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California ![]() ![]() |
My DME for the 3.2L is located vertically just off the floor, in front of the stock backpad and behind the passenger seat. Relay is next to it with a spare in the glovebox. The seat still retracts but not quite fully flush into the backpad. Works well and no moisture access. Ditto...... (IMG:style_emoticons/default/smilie_pokal.gif) |
@mepstein - true, yes, but a bit embarrassing I got my parts confused . Anymore pictures of how you guys mounted them on the inside to the backpad? Did you weld some mounting screws on the firewall and then have them poke through the backpad? Thanks ( and happy Saturday to everyone ) I wouldn’t mount the dme until you get all the wires figured out. Then you can see what you really have to work with It’s much better to put your car together and get it running before you set the interior. It’s also useful to have an old seat for testing. Can’t tell you how many times the techs at the shop would sit down on a finished interior with grease on their clothes or a tool in their back pocket. (IMG:style_emoticons/default/headbang.gif) |
Tdskip |
@mepstein - true, yes, but a bit embarrassing I got my parts confused . Anymore pictures of how you guys mounted them on the inside to the backpad? Did you weld some mounting screws on the firewall and then have them poke through the backpad? Thanks ( and happy Saturday to everyone ) I wouldn’t mount the dme until you get all the wires figured out. Then you can see what you really have to work with It’s much better to put your car together and get it running before you set the interior. It’s also useful to have an old seat for testing. Can’t tell you how many times the techs at the shop would sit down on a finished interior with grease on their clothes or a tool in their back pocket. (IMG:style_emoticons/default/headbang.gif) Sage advice, thanks! |
Lo-Fi Version | Time is now: 7th September 2025 - 01:18 PM |
