Oil catch can, Where should it go? |
brooks944 |
Dec 21 2019, 05:27 PM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Hi everyone, happy holidays! I have a ‘74 1.8 that has been rebuilt with twin Weber’s, cam, etc. I had one of our great senior members help with some carb issues and he suggested I need an oil catch can for the outlet where the oil filler vent used to go to the FI. I bought one of them and not sure where it should be mounted, plus it has an inlet and outlet. Where does the outlet line go? Your pictures would be very helpful. Appreciate any guidance!
Thanks, Rick |
barefoot |
Dec 22 2019, 10:34 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I got this probably off Amazon, could have been local FLAPS also.
it needs to be not very tall as vertical space is limited. Bottom goes to oil vent at filler & vapors go to top of carb air cleaner. It had 2 extra ports I just capped. So far with about 50 miles on new build, haven't seen any oil collect in the tubes. |
brooks944 |
Dec 22 2019, 05:18 PM
Thanks. How did you cut the hole for venting into the air cleaner? Not sure I want to do that. Any other suggestions and pictures out there from other members?
Thanks again! |
Ansbacher |
Dec 22 2019, 08:05 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Here's what mine looks like using a Claude's Buggies catch box with Dual Dellorto 40 carbs. The hoses connect as follows:
Oil Filler Neck to Catch Box Catch Box to Driver Side Carb Air Cleaner Catch Box to Driver Side Port adjacent to Intake Base Catch Box to Passenger Side Port adjacent to Intake Base Ansbacher |
brooks944 |
Dec 23 2019, 05:19 PM
Thanks! I already bought a catch can, and it has one inlet and one outlet. Can I vent the outlet below the car and not connect to either carb air filter?
mtndawg |
Dec 24 2019, 12:50 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I have this hose out where the rain tube goes.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:35 PM |
