914-6 14-pin connector (main harness) |
Philippe |
Dec 22 2019, 04:43 AM
Newbie Group: Members Posts: 14 Joined: 8-December 11 From: Belgium Member No.: 13,877 Region Association: None |
Hi,
Does anybody have a good picture (or wiring diagram) of the main 14-pin harness connector with the cap removed (the one that is connected to the main relay board). I have a brown-white (maybe brown-gray) wire arriving at this connector and have no clue where it plugs in. Even worse...this wire is not referenced in Art Zaft 914-6 wiring diagram. Thanks for any help. Philippe |
Rleog |
Dec 22 2019, 06:01 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
I don’t intend to confuse here, but this might help. I have a 914-4 wiring diagram that shows a grey/brown wire that runs between the back up lights and T14 terminal 4.
Caution: 914-4 and 914-6 may be different. Check your back up lights and see if they have a grey/brown lead wire. |
rgalla9146 |
Dec 22 2019, 07:52 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Both connectors at the 6 relay board are 14 pin.
The one going to the engine harness does not have a wire like your photo. Maybe a Euro feature ? I'll try to access the connector going into the relay board. Attached thumbnail(s) |
sixnotfour |
Dec 22 2019, 08:40 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
sixnotfour |
Dec 22 2019, 09:01 AM
al kosmal added notes
rgalla9146 |
Dec 22 2019, 09:25 AM
Chassis into the relay board
don't see a wire like yours in either connector Attached thumbnail(s) |
rgalla9146 |
Dec 22 2019, 09:29 AM
Philippe |
Dec 22 2019, 10:19 AM
Both connectors at the 6 relay board are 14 pin. The one going to the engine harness does not have a wire like your photo. Maybe a Euro feature ? I'll try to access the connector going into the relay board. This is right. I meant the main harness connector and not the engine connector (both having 14 pins). |
Philippe |
Dec 22 2019, 10:29 AM
Philippe |
Dec 22 2019, 10:36 AM
So far I come to the following pin assignment (looking at the backside of the connector):
1 Yellow 2. Blue 3. Red 4. Green 5. Yellow/Red 6. Green/Black 7. Green 8. Green/Red 9. Not assigned? 10. Gray/Brown 11. Black/Red 12. Gray/Brown 13. Brown 14. Black/Purple |
rgalla9146 |
Dec 22 2019, 12:01 PM
Luke M |
Dec 22 2019, 01:00 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Chassis into the relay board don't see a wire like yours in either connector Nice! Thank you. What colour do you have on pin 9 (starting from the top, left side, 5th pin)? Appears to be brown with white tracer I just checked my factory 6 and my new Kroon wire harnesses. Both brown with a white tracer go to pin #9. Attached image(s) |
rgalla9146 |
Dec 22 2019, 02:17 PM
Wow.
Note to self; schedule thorough harness cleaning |
toolguy |
Dec 22 2019, 03:29 PM
As i remember, there are a couple [2] of wiring color code errors on the 914-6 relay board in the Art Zaft diagram
Philippe |
Dec 23 2019, 02:47 AM
Chassis into the relay board don't see a wire like yours in either connector Nice! Thank you. What colour do you have on pin 9 (starting from the top, left side, 5th pin)? Appears to be brown with white tracer I just checked my factory 6 and my new Kroon wire harnesses. Both brown with a white tracer goes to pin #9. Thanks a lot for the nice pics. I have the answer to my question! Even if the tracer is different, the basic brown/white colour of pin 9 remains the same. What still bothers me is the fact that this brown/white wire is not documented. BTW Kroon did an excellent job. The welding work at the connector is well done. Thanks to you all for the support. Philippe |
altitude411 |
Dec 23 2019, 08:07 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
I have wire harness envy... (IMG:style_emoticons/default/shades.gif)
gerakroo |
Mar 20 2020, 03:27 AM
Newbie Group: Members Posts: 15 Joined: 27-June 14 From: Sappemeer Member No.: 17,563 Region Association: Europe |
Chassis into the relay board don't see a wire like yours in either connector Nice! Thank you. What colour do you have on pin 9 (starting from the top, left side, 5th pin)? Appears to be brown with white tracer I just checked my factory 6 and my new Kroon wire harnesses. Both brown with a white tracer goes to pin #9. Thanks a lot for the nice pics. I have the answer to my question! Even if the tracer is different, the basic brown/white colour of pin 9 remains the same. What still bothers me is the fact that this brown/white wire is not documented. BTW Kroon did an excellent job. The welding work at the connector is well done. Thanks to you all for the support. Philippe Thank you ! |
rgalla9146 |
Mar 20 2020, 07:54 AM
Well a year and three months later (almost to the day) i believe I have the answer.
It is the wire for the switch incorporated in the shift knob of Sportomatic cars. The white car harness is re-wrapped. The yellow is untouched. Attached thumbnail(s) |
dr914@autoatlanta.com |
Mar 20 2020, 09:00 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I agree, there is a factory six factory drawn wiring diagram out there, we have enlarged copies of it
I don’t intend to confuse here, but this might help. I have a 914-4 wiring diagram that shows a grey/brown wire that runs between the back up lights and T14 terminal 4. Caution: 914-4 and 914-6 may be different. Check your back up lights and see if they have a grey/brown lead wire. |
rgalla9146 |
Mar 20 2020, 09:56 AM
I agree, there is a factory six factory drawn wiring diagram out there, we have enlarged copies of it I don’t intend to confuse here, but this might help. I have a 914-4 wiring diagram that shows a grey/brown wire that runs between the back up lights and T14 terminal 4. Caution: 914-4 and 914-6 may be different. Check your back up lights and see if they have a grey/brown lead wire. ....what is it that you agree with ? |
Lo-Fi Version | Time is now: 15th May 2024 - 05:23 PM |
