synthetic oil, 1974 914 1.8 |
brcacti |
Dec 22 2019, 05:26 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars?
Superhawk996 |
Dec 22 2019, 05:35 PM
914 Guru Group: Members Posts: 5,835 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Oh boy. . . . now you've done it. (IMG:style_emoticons/default/popcorn[1].gif)
sholman5 |
Dec 22 2019, 05:42 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Let the games begin. (IMG:style_emoticons/default/beer3.gif)
JFJ914 |
Dec 22 2019, 05:45 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I use the Driven DT 50, doesn't leak all over.
JawjaPorsche |
Dec 22 2019, 05:58 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Our teeners need a high zinc content oil.
thelogo |
Dec 22 2019, 06:54 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Forget aircooled if you put it in a 914 your a clown
I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob |
BENBRO02 |
Dec 22 2019, 08:11 PM
Member Group: Members Posts: 481 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Forget aircooled if you put it in a 914 your a clown I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob Driven DT50 is a synthetic with high ZDDP that was specifically developed for our aircooled engines. Jake Raby helped develop it. I just bought 12 quarts but haven't tried it yet. |
Coondog |
Dec 22 2019, 08:20 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars? Just use Castrol 20w/50 and you will be fine and have more money in your pocket. |
BENBRO02 |
Dec 22 2019, 08:27 PM
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars? Just use Castrol 20w/50 and you will be fine and have more money in your pocket. Will the engine turn over when it's 20°F with Castrol 20w/50? |
IronHillRestorations |
Dec 22 2019, 08:30 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I always recommend a high zinc oil for air cooled engines with solid lifters, as most "regular" oil doesn't have enough ZDDP to prevent premature cam/lifter wear. Valvoline VR1 is usually easy to find and has an appropriate level of zinc, but Drive DT50 is formulated for air cooled engines with solid lifters.
Rotella, Delo, and other oils designed for diesel engines have enough zinc, but there's detergent and additives that could be detrimental to our air cooled engines. Use a high ZDDP oil and change it every 4k miles or at least once a year, before you put your car up for the winter |
Coondog |
Dec 22 2019, 08:40 PM
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars? Just use Castrol 20w/50 and you will be fine and have more money in your pocket. Will the engine turn over when it's 20°F with Castrol 20w/50? He lives in Phoenix..... (IMG:style_emoticons/default/poke.gif) |
BENBRO02 |
Dec 22 2019, 08:44 PM
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars? Just use Castrol 20w/50 and you will be fine and have more money in your pocket. Will the engine turn over when it's 20°F with Castrol 20w/50? He lives in Phoenix..... (IMG:style_emoticons/default/poke.gif) Great point. I had to look up Phoenix temperatures. |
Big Len |
Dec 22 2019, 11:15 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Forget aircooled if you put it in a 914 your a clown I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob Clown? Really? Driven DT50, made for A/cooled Porsche's, is a synthetic. Amsoil, ZRod high zinc oil is a synthetic. Brad Penn is a synthetic blend. Give an opinion but try to not come off like an ass. |
thelogo |
Dec 23 2019, 08:17 AM
Forget aircooled if you put it in a 914 your a clown I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob Clown? Really? Driven DT50, made for A/cooled Porsche's, is a synthetic. Amsoil, ZRod high zinc oil is a synthetic. Brad Penn is a synthetic blend. Give an opinion but try to not come off like an ass. Sorry i meant if you use over the counter synthetic oil (IMG:style_emoticons/default/beer3.gif) |
Front yard mechanic |
Dec 23 2019, 09:39 AM
Senior Member Group: Members Posts: 1,165 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I'm a cheap sob I use Walmart 20 50 and add 1 oz of zinc additive works great for 15.00 and I can pick up some cheese puffs while I'm there
Dec 23 2019, 10:02 AM
Here's all you need to know:
Pelican oil thread Pelican ultimate oil thread It's your car, you can use maple syrup if you want, but I'll stick with what I believe to be the best (IMG:style_emoticons/default/biggrin.gif) |
dr914@autoatlanta.com |
Dec 23 2019, 10:05 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no synthetic in a 914 unless you want oil leaks
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars? |
injunmort |
Dec 23 2019, 11:19 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I don't use synthetics in air cooled engines. I wont pay up for gibbs, driven or brad penn. vr1 available at flaps and been using it for 25 plus year in my aircooleds, never a problem. cant argue with Wal-Mart 20-50 plus zddp additive though. the oil gets change so frequently in these cars and drivers are not subjected to extreme operation, it makes eco sense. I buy vr1 when there is sale at flaps and done with it. castrol 20-50 is a great sub for vr1 in a pinch.
brcacti |
Dec 23 2019, 03:51 PM
THANK YOU SO MUCH guys, the former owners used castrol 30w like the owners manual says so I think I will stick with it BUT I did have some additional questions for those who would like to answer them. I did write down the DT50 with the high ZDDP in case I ever want to change.
I am in a high heat zone between PHX and Tucson, AZ so I only drive it in 6 winter/fall/spring months when dry and mornings are over 32F. Don't drive it in summer heat 5-6 months but start it up once weekly in cool mornings. I'm 66 and drive like an old lady for the fun factor and blast from the past factor. I am guessing 2500-3000 miles per year short trips to work and back. A couple of questions are does the castrol 30 have zinc in it? Should I change the oil before I use it for the 6 months or after I use it for the 6 months? |
djway |
Dec 23 2019, 11:12 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I have a high top VW bus with a T4 and have run nothing but synthetic. Had it over 5 years and not a leak yet. Run it in all my AirCooled. Depends on how well they were put together.
Risoline has a ZDDP additive for $10. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:22 PM |
