Anti-roll bar Help!, Smart Racing anti-roll bar |
Rog914 |
Jul 2 2005, 05:43 PM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
Getting ready to install a Smart Racing anti-roll bar(front). But not exactly sure how to install. Do i center the bearing mount to the "cresent" or should it be a little higher or lower? Plus the backing ring will not fit unless you cut some sheet metal from the inside where the gas tank was.
Has anybody else installed one of these anti-roll bars? Any info will be a great help, Thanks, Ralph 74 2.0 |
Trekkor |
Jul 2 2005, 06:10 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I'm your guy! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Just a minute... I have all the pictures, too. KT Attached image(s) |
Trekkor |
Jul 2 2005, 06:17 PM
Here:Install thread
What size bar are you installing? I'm using the 31mm...( yes ). (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) KT |
Trekkor |
Jul 2 2005, 06:33 PM
Also take note of this: Like you said.
You must relieve the area inside of the inner fender well under the fuel tank. I just pushed it aside with my air chisel. ( don't look if you are offended ) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Also, when you slide the bar through the fender well bearings for the first time and the bar binds up a bit. Pull the bar out towards one side or the other and leaving it still inserted through the one side, use the bar as a lever to slightly tweak the fender well until the bearings are alligned. Only takes a moment or two. Have fun... Six hour job. Use spray lithium grease, too. KT Oh yeah, one more thing. Make sure the kit you have has two spacers for each side as this kit, which works on the 914, is designed for the narrower 911. |
Trekkor |
Jul 2 2005, 06:38 PM
Hi! Me again (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Use the supplied drop link to "A-Arm" mounting bracket, not the stock sway bar mounts that may be on your car now. I had mine on the stock brackets until one of the SRP guy's was at the a/x and told me to use the parts they provided. I had 'em with me and he helped me with the install. Something about better geometry and it being less likely to break off the car. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) KT |
KenH |
Jul 2 2005, 08:18 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Trekkor,
Looks like you should put in Turbo-tie rods. Ken |
Rog914 |
Jul 2 2005, 08:25 PM
Thanks Trekkor for the info & pics.
I'm installing there 20mm bar. It's going to be mainly a street driven teener. I'm finally putting all the stuff I've acumulated over the past 2 years on the car. Thanks again for the quick responce. Ralph White 74 2.0 soon to have all gray interior |
Trekkor |
Jul 2 2005, 11:17 PM
I did...And I love 'em. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Hope that helps, Ralph. KT |
Lo-Fi Version | Time is now: 20th May 2024 - 03:40 PM |
