vitaminc914 |
Newbie ![]() Group: Members Posts: 30 Joined: 4-July 05 From: Allendale, MI Member No.: 4,374 Region Association: Upper MidWest ![]() |
I have a 74 914/2.0 I am looking to get a COA from Porsche and they are asking for the engine and transmission numbers. Here is what I found. I am sure the Engine is accurate but I am not sure if the transmission number is the correct one.
Engine GA011080 Trans HA16103 Car is built 10/1973 |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
I have a 74 914/2.0 I am looking to get a COA from Porsche and they are asking for the engine and transmission numbers. Here is what I found. I am sure the Engine is accurate but I am not sure if the transmission number is the correct one. Engine GA011080 Trans HA16103 Car is built 10/1973 Yes< those are the correct numbers |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,549 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Isn't the whole point of a COA for Porsche to tell YOU what the original engine and transaxle numbers are, based on chassis/VIN?
If they're just gonna use your number to create a COA...then where's the value? |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,230 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
YOU have to give them the numbers for the current COA style document. PORSCHE will NOT give you the correct engine number unless you porvide it. It seems that NONE of the transmission numbers were recorded. The stamped number on the trans will give an indication on when it was built.
GregAmy |
YOU have to give them the numbers for the current COA style document. PORSCHE will NOT give you the correct engine number unless you porvide it. It seems that NONE of the transmission numbers were recorded. The stamped number on the trans will give an indication on when it was built. So then...where's the value of paying for a COA? How "A" is the "C" if they're simply writing the numbers you give them on pretty letterhead with a Porsche crest in the upper left corner? (a.k.a., are buyers really that gullible...?) |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,024 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
YOU must provide the numbers of the engine in your car and THEY will verify that their numbers match yours. IF they match, they indicate them on the PPS, if no match they are not indicated. Seems some people were telling them their current engine, which was not original, and trying to get that on the PCNA COA/PPS. This is their way of managing that to keep everyone honest
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Well, Porsche knows what the engine numbers are. They’re just verifying it for you. They won’t give it to you if you don’t know (or the engine number is wrong) to prevent the engine getting restamped to the correct number.
JFJ914 |
Isn't the whole point of a COA for Porsche to tell YOU what the original engine and transaxle numbers are, based on chassis/VIN? If they're just gonna use your number to create a COA...then where's the value? The COA is Dead, it was replaced by the new Porsche Classic Technical Certificate ($500). Obviously, it is of no value to you. It would only work for a valuable car like 914-6. They will not give you the numbers anymore because they are tired of being sued for aiding counterfeiters in defrauding buyers thinking the cars are real and numbers matching. This is not a program for the average 914-4. |
JeffBowlsby |
To be clear, the COA document formerly issued by PCNA, is no longer available but it has been replaced by the PPS.
https://www.pca.org/resource/porsche-certif...uthenticity-coa The Porsche Classic Technical Certificate is available through Porsche Classic dealers. ![]() |
sholman5 |
Kraut burner ![]() ![]() Group: Members Posts: 191 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States ![]() ![]() |
The PPS application does not even ask for engine and trans #. The only numbers that it asks for is the vin and your credit card number.
Lo-Fi Version | Time is now: 31st August 2025 - 07:18 AM |
