Throttle to Plenum seal |
PCH |
Dec 23 2019, 02:27 PM
Member Group: Members Posts: 140 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
When placing a new throttle body to plenum gasket, do you put some sort of sealer (like Formagasket) on the gasket?
The previous gasket had a sealer on it. Thank you for your help. Peter |
rjames |
Dec 23 2019, 04:29 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
When placing a new throttle body to plenum gasket, due you put some sort of sealer (like Formagasket) on the gasket? The previous gasket had a sealer on it. Thank you for your help. Peter You shouldn’t need it if the surfaces of the TB and plenum are super clean. Torque down the bolts each a little at a time. |
rjames |
Dec 23 2019, 04:31 PM
Double post
DRPHIL914 |
Dec 23 2019, 09:37 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Common spot for vac leak, there is a gasket that should be placed between there at least I have always had one on my 2.0 D-jet
Attached thumbnail(s) |
iankarr |
Dec 23 2019, 10:34 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
A thin smear (thin!) of The Right Stuff can’t hurt.
rjames |
Dec 23 2019, 11:16 PM
DRPHIL914 |
Dec 24 2019, 08:26 AM
Common spot for vac leak, there is a gasket that should be placed between there at least I have always had one on my 2.0 D-jet Gasket yes. Goop isn’t needed if surfaces are properly prepped. (IMG:style_emoticons/default/headbang.gif) Sorry, it was late and I was not reading clearly the OP, lol but I agree o goop needed just gasket- |
PCH |
Dec 24 2019, 01:43 PM
Thanks everyone for your help!
Lo-Fi Version | Time is now: 20th May 2024 - 12:53 AM |
