Are Amber (Euro) Rear Turnsignals in USA Fixtures DOT Compliant?, Rear Euro Sidemarker in USA Fixture is Amber, not Red |
Mark Henry |
Jan 6 2020, 11:01 AM
edit
Mark Henry |
Jan 6 2020, 11:03 AM
Seems like if we could get the side markers to light up through the amber lenses, it would be a win-win for US/Canada drivers. This my ghetto duct seal tape solution. Just bent a piece of alunimum tape and stuck it on making a bit of a divider/hood. (IMG:http://www.914world.com/bbs2/uploads/post-26-1578329041.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-26-1578329063.jpg) A couple of notes, -At night the turn light area still glows a tad, from directly behind the car maybe 1/10th as bright as the running light. -The clear reflector lens in the housing is suppose to be glued in, but mine pulled out easy and when installed it's trapped between the housing and lens. -I thought about taping right to the clear reflector but I still wanted the turn signal light to wrap around the corner of the lens. -In the pics the first shot is of the left side, 2nd pic is the right side because I couldn't get a good pic of the left. -A better solution could likely be made out of thin alunimum sheet, I'll try this in the future if the tape falls off. -Yes I have two orange 914's (IMG:style_emoticons/default/wink.gif) |
dr914@autoatlanta.com |
Jan 6 2020, 11:15 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Dead on: A HEINOUS crime!
Officer: "Do you know why I pulled you over?" Guy: "Um, no sir." Officer: "Your reg shows that's a 1972 car" Guy: "Yes, sir?" Officer: "You have amber rear turn signal lenses." Guy: "Um, ok...?" Officer: "Please step out of the car, sir, with your hands in clear view." |
Spoke |
Jan 16 2020, 07:57 PM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The first amber rear turnsignal board with red sidemarker LEDs. Looks pretty cool.
Here's the lens w/o any lights on. Amber look all around the corner. With the running lights on, the sidelight appears red as it should be for the rear sidemarker. |
Chi-town |
Jan 16 2020, 08:02 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
If it doesn't have the SAE/DOT stamp on it, it's illegal. That stamp is actually part of the requirement.
Jan 16 2020, 08:36 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Montreal914 |
Jan 17 2020, 12:38 AM
Senior Member Group: Members Posts: 1,562 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Very nice! (IMG:style_emoticons/default/smilie_pokal.gif)
It is interesting to see that the red light doesn't propagate to the blinker portion of the lens. I assume it is because the LEDs are very directional. This means we don't need Mark's ghetto fix with aluminum tape (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Will eventually pull the trigger on some of these beauties. (IMG:style_emoticons/default/beerchug.gif) |
eric9144 |
Mar 13 2020, 09:43 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Reviving this thread because I installed some of these beauties tonight. The red outer marker is pretty awesome in the euro lenses:
@spoke (IMG:style_emoticons/default/aktion035.gif) |
RickS |
Mar 13 2020, 10:26 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Adopted Mr. Henry’s ingenious (ghetto) solution on the cheap. “Works great, less filling”
But the LED solution is ingenious and looks great. |
Lo-Fi Version | Time is now: 22nd May 2024 - 06:40 AM |
